I am using asp.net along with JavaScript to develop a webpage that will display a map,
Basically, I am loading an image service and a map service, selecting a feature and zooming to that feature. The code works about 90% of the time. When it does fail, it will load the map service and zoom to the proper extent, but it DOES NOT load the image service or select a feature.
It appears the instigator either the query or the or the feature selection - if I remove the call to doMaps(), the code never fails.
Does anyone have any experience in this area?
I have attached two images as examples. This is the code I am using:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head >
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title></title>
<script src="http://js.arcgis.com/3.7/" type="text/javascript"></script>
<script>
var MN, ParcelMap, sfs, queryTask;
var featurelayer;
require(["esri/map","dojo/on","dojo/parser","esri/layers/ArcGISDynamicMapServiceLayer","esri/layers/ArcGISImageServiceLayer","esri/renderers/SimpleRenderer","dojo/_base/connect","dojo/dom","dojo/query","esri/graphic","esri/layers/FeatureLayer","dojo/domReady!"],
function (Map, on, parser, ArcGISDynamicMapServiceLayer, ArcGISImageServiceLayer, SimpleRenderer, connect, dom, query, Graphic, FeatureLayer) {
parser.parse();
queryTask = new esri.tasks.QueryTask("http://MapServer/2");
MN = "5"
//define maps
ParcelMap = new esri.Map("ParcelMap");
var layer1 = new esri.layers.ArcGISImageServiceLayer("http://ImageServer");
ParcelMap.addLayer(layer1);
var layer2 = new esri.layers.ArcGISDynamicMapServiceLayer("http:///MapServer");
ParcelMap.addLayer(layer2);
ParcelMap.on("load", doMaps());
function doMaps() {
sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 255, 255]), 2));
//create selection layer
featureLayer = new esri.layers.FeatureLayer("http://MapServer/2", {
mode: esri.layers.FeatureLayer.MODE_SELECTION
featureLayer.setSelectionSymbol(sfs);
//add selection layer to map
ParcelMap.addLayers([featureLayer]);
//set up query
query = new esri.tasks.Query();
query.returnGeometry = true;
query.where = "MAP_NO = '" + MN + "'";
//select parcel
featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (features) {
if (features.length == 0) {
alert("No Parcel Found");
else {
//zoom to the selected feature
parcelExtent = features[0].geometry.getExtent().expand(1.5);
ParcelMap.setExtent(parcelExtent);
</script>
</head>
<body class="tundra">
<form id="form1" runat="server">
<div id="ParcelMap" style="width:400px; height:400px;runat="server"></div>
</form>
</body>
</html>
