JavaScript API Print Widget / dom.byID
2277
5
11-08-2017 09:28 AM
DonaldShaw5
I am trying to set up a map that classifies Colorado peaks by their unique values (Class of peak) and allows the user to print the map. I had the map displaying nicely until I tried to implement the print widget. Somewhere I became lost in the code and keep receiving the error "dom.byID is not a function." I have used the samples for Unique Values Renderer and the Print widget but I can not get them all into one functioning map.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Unique Value Renderer</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.22/dijit/themes/nihilo/nihilo.css">
  <style>
    html, body, #map{
      height: 100%;
      margin: 0;
      padding: 0;
    #rightPane{
      margin: 0;
      padding: 10px;
      background-color: #fff;
      color: #421b14;
      width: 180px;
    #printButton {
      width: 160px;
  </style>
  <script src="https://js.arcgis.com/3.22/"></script>
  <script>
    var app = {};
    app.map = null; app.toolbar = null; app.tool = null; app.symbols = null; app.printer = null;
    require([
      "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Print",
      "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol",
      "esri/renderers/UniqueValueRenderer", "esri/Color", "esri/config", "dojo/dom", "dijit/form/Button",
      "dojo/domReady!"
    ], function(
      Map, Print, FeatureLayer,
      SimpleLineSymbol, SimpleFillSymbol, graphic,
      UniqueValueRenderer, Color, parser, dom, Button
      esriConfig.defaults.io.proxyUrl = "/proxy/";
      app.map = new Map("map", {
        basemap: "streets",
        center: [-105.78, 39.55],
        zoom: 6,
        slider: false
      app.printer = new Print({
        map: app.map,
        url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%..."
      }, dom.byId("printButton"));
      app.printer.startup();
      var uvrJson = {
        "type": "uniqueValue",
        "field1": "Class",
        "defaultSymbol": {
          "color": [0, 0, 0, 64],
          "outline": {
            "color": [0, 0, 0, 255],
            "width": 1,
            "type": "esriSMS",
            "style": "esriSMSCircle"
          "type": "esriSMS",
        "uniqueValueInfos": [{
          "value": "Class 1",
          "symbol": {
            "color": [255, 204, 204, 1],
            "outline": {
              "width": 1,
              "type": "esriSMS",
            "type": "esriSLS",
            "style": "esriSLSSolid"
          "value": "Class 2",
          "symbol": {
            "color": [255, 102, 102, 1],
            "outline": {
              "width": 1,
              "type": "esriSMS",
            "type": "esriSLS",
            "style": "esriSLSolid"
            "value": "Class 3",
            "symbol": {
              "color": [255, 0, 0, 1],
              "outline": {
                "width": 1,
                "type": "esriSMS",
              "type": "esriSLS",
            "value": "Class 4",
            "symbol": {
              "color": [102, 0, 0, 0],
              "outline": {
                "width": 1,
                "type": "esriSMS",
              "type": "esriSLS",
      var renderer = new UniqueValueRenderer(uvrJson);
      var featureLayer = new FeatureLayer("https://services.arcgis.com/IZtlGBUe4KTzLOl4/ArcGIS/rest/services/Colorado14ers/FeatureServer/0", {
        infoTemplate: new InfoTemplate(" ", "${Class}"),
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields: ["Class"]
      app.map.addLayer(featureLayer);
      featureLayer.setRenderer(uvrjson);
  </script>
</head>
<body>
<div id="map"></div>
<div id="rightPane"
     data-dojo-type="dijit/layout/ContentPane"
     data-dojo-props="region:'right'">
  <div id="printButton"></div>
  <hr />
</div>
</body>
</html>
RobertScheitlin__GISP
Donald,
   OK, I missed the fact that you have graphic in your vars but not in your module require list:
require([
      "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol", "esri/Graphic",
      "dojo/parser", "dojo/dom", "dijit/form/Button",
      "dojo/domReady!"
    ], function(
      Map, FeatureLayer, Print,
      SimpleLineSymbol, SimpleMarkerSymbol, graphic,
      UniqueValueRenderer, Color, esriConfig, parser, dom, Button
Donald,
   You are making a mistake that most beginner JS Developers make with they are unfamiliar with AMD style coding.
Your module require list and their subsequent vars have to be in the same order. You have:
    require([
      "dojo/domReady!"
    ], function(
You need:
    require([
      "dojo/domReady!"
    ], function(
DonaldShaw5
Mr. Scheitlin, nice catch, but I am now receiving an error "Uncaught TypeError: Cannot read property 'io' of undefined" referring to
Any thoughts on this?
Donald,
require([
      "dojo/domReady!"
    ], function(
Donald,
   You had a reply here a while ago that seemed like you were having more problems. Did you delete it because you are good to go now? If so then don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
DonaldShaw5
Sorry about that, I forgot to add the comment after removing the last one. I was able to get the print button to generate but not in the position that I wanted.  This was after rearranging the <style> section and the divs down in the body. For now it will work. JavaScript has been quite a big learning curve, but it is good to dive in and see how things work! Next up for me is finding out about Legends! Thanks for everything, here is the code that got it to finally populate!
<!DOCTYPE html>
<html>
<head>
  <style>
    html, body, #map{
      height: 100%;
      margin: 0;
      padding: 0;
    body{
      background-color: #fff; overflow:hidden;
      font-family: sans-serif;
    label {
      display: inline-block;
      padding: 5px 5px 0 5px;
      font-weight: 400;
      font-size: 12pt;
    .button {
      width: 100%;
      margin: 3px auto;
      text-align: center;
    #header {
      padding-top: 4px;
      padding-right: 15px;
      color: #444;
      font-size:16pt; text-align:right;font-weight:bold;
      height:55px;
      background: #fff;
      border-bottom: 1px solid #444;
    #subheader {
      font-size:small;
      color: #444;
      text-align:right;
      padding-right:20px;
    #rightPane{
      margin: 0;
      padding: 10px;
      color: #421b14;
      width: 180px;
    /* make all dijit buttons the same width */
    .dijitButton .dijitButtonNode, #printButton
    {width: 160px;}
    .esriPrint {
      padding: 0;
  </style>
  <script>
    var app = {};
    require([
      "esri/map", "esri/layers/FeatureLayer", "esri/InfoTemplate", "esri/dijit/Print",
      "dojo/parser","dojo/query", "dojo/dom", "dijit/form/Button",
      "dojo/domReady!"
    ], function(
      Map, FeatureLayer, InfoTemplate, Print,
      UniqueValueRenderer, Color, esriConfig, parser, query, dom, Button
      parser.parse();
        basemap: "streets",
        zoom: 6,
        slider: false
        map: app.map,
      var uvrJson = {
        "field1": "Class",
        "defaultSymbol": {
          "outline": {
            "width": 1,
            "type": "esriSMS",
          "type": "esriSMS",
          "value": "Class 1",
          "symbol": {
            "outline": {
              "width": 1,
              "type": "esriSMS",
            "type": "esriSLS",
          "value": "Class 2",
          "symbol": {
            "outline": {
              "width": 1,
              "type": "esriSMS",
            "type": "esriSLS",
            "value": "Class 3",
            "symbol": {
              "outline": {
                "width": 1,
                "type": "esriSMS",
              "type": "esriSLS",
            "value": "Class 4",
            "symbol": {
              "outline": {
                "width": 1,
                "type": "esriSMS",
              "type": "esriSLS",
  </script>
</head>
<body class="nihilo">
<div id="mainWindow"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline',gutters:false"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="header"
       data-dojo-props="region:'top'">
    Colorado 14ers Map
    <div id="subheader"></div>
  </div>
  <div id="map" class="shadow"
       data-dojo-props="region:'center'"><div id="ds">
<div id="rightPane"
  <hr />
</div>
  </div>
  </div>
</div>
</body>
</html>
