I am not able to perform a GoTo operation with a Zoom option. I have tried on multiple targets including individual/multiple graphics and geometries, which should work according to the reference.
Here is sample code I'm using to replicate the issue:
<!DOCTYPE html>
<html>
<head>
<title>GoTo Operation with Zoom</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css">
<script src="https://js.arcgis.com/4.2/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/symbols/SimpleMarkerSymbol",
"esri/geometry/Point",
"esri/Graphic",
"esri/geometry/SpatialReference",
"dojo/domReady!"
], function (Map, MapView, SimpleMarkerSymbol, Point, Graphic, SpatialReference) {
var map = new Map({
basemap: 'hybrid'
var view = new MapView({
center: [-84.3852995, 33.7678835],
container: "viewDiv",
map: map,
zoom: 13
var iconPath = "M12 2C6.48 2 2 6.48 2 12s4.48 10 10 10 10-4.48 10-10S17.52 2 12 2z";
var markerSymbol = new SimpleMarkerSymbol(
path: iconPath,
color: "#3F51B5",
outline: {
color: [255, 255, 255],
width: 1
var point = new Point({
longitude: -84.3852995,
latitude: 33.7678835,
spatialReference: SpatialReference.WGS84
var pointGraphic = new Graphic({
geometry: point,
symbol: markerSymbol
view.graphics.add(pointGraphic);
var options = {
zoom: 5
view.goTo(point, options);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
I'm getting the following exception:
TypeError: Cannot read property 'wkid' of null
at v (MapView.js:35)
at y (MapView.js:38)
at Object.m.createAsync (MapView.js:45)
at Object.m.goTo (MapView.js:15)
at esriLoader.require.Viewpoint.generateRandomPoints (AngularMap.html:115)
at AngularMap.html:249
at angular-esri-map@2.0.1:118
at processQueue (angular.js:15961)
at angular.js:15977
at Scope.$eval (angular.js:17229)
