I have a form that I am using to add or edit points to a map. Is there a way on start up to clear the form of any pre-existing data on load?
Here is my form:
<div id="attributesSignModal" class="modal fade" style="display: none;" aria-hidden="true"> <!-- Modal Dialog Begin --> <div class="modal-dialog"> <div class="modal-content"> <div class="modal-header"> <button type="button" class="close" data-dismiss="modal" aria-hidden="true">×</button> <h4 class="modal-title">Add/Edit Sign</h4> </div> <div class="modal-body"> <!-- Installed Begin --> <div class="form-group"> <label for="installed">Installed</label> <input type="date" class="form-control" name="installed" id="installed" /> </div> <!-- Installed End --> <!-- Sign ID Begin --> <div class="form-group"> <label for="signId">Sign ID</label> <input type="number" class="form-control" placeholder="Sign ID" name="signId" id="signId" /> </div> <!-- Sign ID End --> <!-- Facing Begin --> <div class="form-group"> <label for="facing">Facing</label> <input type="text" class="form-control" placeholder="Facing" name="facing" id="facing" /> </div> <!-- Facing End --> <!-- Visibility Begin --> <div class="form-group"> <label for="visibility">Visibility</label> <select id="visibility" class="form-control" name="visibility"> </select> </div> <!-- Visibility End --> <!-- Condition Begin --> <div class="form-group"> <label for="condition">Condition</label> <select id="condition" class="form-control" name="visibility"> </select> </div> <!-- Condition End --> <!-- Support ID Begin --> <div class="form-group"> <label for="supportId">Support ID</label> <input type="number" class="form-control" name="supportId" id="supportId" /> </div> <!-- Support ID End --> <!-- Text Begin --> <div class="form-group"> <label for="text">Text</label> <input type="text" class="form-control" name="text" id="text" /> </div> <!-- Text End --> <!-- Color 1 Begin --> <div class="form-group"> <label for="color1">Color 1</label> <select id="color1" class="form-control" name="color1" required> </select> </div> <!-- Color 1 End --> <!-- Delineator Begin --> <div class="form-group"> <label for="delineator">Delineator</label> <select id="delineator" class="form-control" name="delineator"> </select> </div> <!-- Delineator End --> <!-- Illum Begin --> <div class="form-group"> <label for="illum">Illum</label> <select id="illum" class="form-control" name="illum"> </select> </div> <!-- Illum End--> <!-- Offset Begin --> <div class="form-group"> <label for="offset">Offset</label> <input type="text" class="form-control" name="offset" id="offset" /> </div> <!-- Offset Ends --> <!-- Mountht Begin --> <div class="form-group"> <label for="mountht">MOUNTHT</label> <input type="text" class="form-control" name="mountht" id="mountht"/> </div> <!-- Mountht End --> <!-- Backing Begin --> <div class="form-group"> <label for="backing">Backing</label> <select id="backing" class="form-control" name="backing"> </select> </div> <!-- Backing End --> <!-- Width Begin --> <div class="form-group"> <label for="width">Width</label> <input type="text" class="form-control" name="width" id="width" /> </div> <!-- Width End --> <!-- Height Begin --> <div class="form-group"> <label for="height">Height</label> <input type="text" class="form-control" name="height" id="height"/> </div> <!-- Height End --> <!-- Txt Size Begin --> <div class="form-group"> <label for="txtSize">Text Size</label> <input type="text" class="form-control" name="txtSize" id="txtSize"/> </div> <!-- Txt Size End --> <!-- Num Size Begin --> <div class="form-group"> <label for="numSize">Numsize</label> <input type="text" class="form-control" name="numSize" id="numSize"/> </div> <!-- Num Size End --> <!-- Comments Begin --> <div class="form-group"> <label for="comments">Comments</label> <input type="text" class="form-control" name="comments" id="comments"/> </div> <!-- Comments End --> <!-- Two Sided Begin --> <div class="form-group"> <label for="twoSided">Two Sided</label> <input type="text" class="form-control" name="twoSided" id="twoSided" /> </div> <!-- Two Sided End --> <!-- Attach Type Begin --> <div class="form-group"> <label for="attachType">Attach Type</label> <select id="attachType" class="form-control" name="attachType"> </select> </div> <!-- Attach Type End --> <!-- Attach Num Begin --> <div class="form-group"> <label for="attachNum">Attach Num</label> <input type="text" class="form-control" name="attachNum" id="attachNum"/> </div> <!-- Attach Num End --> <!-- Attach Loc Begin --> <div class="form-group"> <label for="attachLoc">Attach Loc</label> <select id="attachLoc" class="form-control" name="attachLoc"> </select> </div> <!-- Attach Loc End --> <!-- siteObs Begin --> <div class="form-group"> <label for="siteObs">Siteobs</label> <select id="siteObs" class="form-control" name="siteObs"> </select> </div> <!-- siteObs End --> <!-- Sign Shape Begin --> <div class="form-group"> <label for="signShape">Sign Shape</label> <select id="signShape" class="form-control" name="signShape"> </select> </div> <!-- Sign Shape End --> <!-- Color 2 Begin --> <div class="form-group"> <label for="color2">Color 2</label> <select id="color2" class="form-control" name="color2"> </select> </div> <!-- Color 2 End --> <!-- Mutcd Begin --> <div class="form-group"> <label for="mutcd">MUTCD</label> <select id="mutcd" class="form-control" name="mutcd"> </select> </div> <!-- Mutcd End --> <button class="btn btn-success">Submit</button> <button class="btn btn-default">Cancel</button> <button id="btnPrevious" class="btn navButton" style="visibility:hidden">Previous</button> <button id="btnNext" class="btn navButton" style="visibility:hidden">Next</button> </div> </div> </div> <!-- Modal Dialog End --> </div>
How about something like....
var elems = document.getElementsByClassName("form-control"); for(var i = 0; i < elems.length; ++i) { elems.value = ""; }
Thank you. Tom Wayson also found me this: HTML DOM Form reset() Method
I thought it had to be of a button type.
Nice. Even easier!
