So I have set up a page with my login inputs and map. On submit, username and password are sent to the generateToken endpoint. The token response is passed to ID Manager using the functions below:
function submitCreds(){
var password = passwordInput.get("value");
var email = emailInput.get("value");
var requestHandle = esriRequest({
"url": "arcgis/tokens/generatetoken",
"handleAs": "json",
"content": {
f: "json",
username: email,
password: password,
{usePost: true}
requestHandle.then(requestSucceeded, requestFailed);
function requestSucceeded(response, io){
esri.id.registerToken({
"expires": response['expires'],
"server": "https://myserver/arcgis/rest",
"ssl": true,
"token": response['token'],
"userId": emailInput.get("value")
domConstruct.place("<b>Login Successful!</b>", "login-
result", "last");
Logging in through this form doesn't work to display my secure content and I'm still getting the default ArcGIS Server login dialog when the page loads.
How do I load the secure service after the token has been registered? Also, how can I prevent the default login dialog from appearing?
Thanks for your help!
EDIT: I'm looking at the output of
esri.id.findCredential("myServer/arcgis/rest/services", "myUser");
and the only differences between the output when I sign in with my form and with the default form are that when using the default login prompt, the resources array contains the specific secure layer my app will load (through my form, the array contains the server directory, myserver/arcgis/rest/services), and there are properties validity: 60 and _refreshTimer: 75 that are missing from the credential registered with my form. Do I need to scope the token registration to a specific layer or resource? Or is there another step I need to take to force the app to use the token when it makes the calls to add my secure layer?
EDIT2: Solved my problem. I didn't realize the token has to be registered before the layer object for the secure layer is created. Once I moved the code block that created the layer object, the default login stopped appearing and my login form worked as expected.
