Getting Error Arcgis server 10.4.1 Map Services and geoprocessing services
1884
6
01-19-2017 10:59 PM
PrasadG
Hi...
I Have Problem with map and GeoProcessing Services.  I published the Service to Arcgis Server 10.4.1 From arcmap10.4.1  but time of query in Code it show problem and also my geoprocessing service not working. At same time if i use my arcgis server 10.3 service it will work fine in my code in case of arcgis server 10.4  it show error which I attach..if any solution Please Send.....
Thanks.....
FC_Basson
MVP Regular Contributor
Some additional information might help e.g. is the 10.4 on a different server?  Have you tested the 10.4 GP service through the REST interface before using it in the JS API?  Are you sure the input parameters are correct?
PrasadG
Tested   parameters arc correct...
PrasadG
I got error At console
And Error At Network
FC_Basson
Is your GP tool synchronous or asynchronous?  The synchronous service uses the "execute" directive while the asynchronous service uses the "submitJob" directive to execute.
PrasadG
hi..basson thanks for reply....i am using synchronous with execute method. I saw AGS logs error is like....
FC_Basson
According to this page: https://support.microsoft.com/en-us/help/193625/info-wininet-error-codes-12001-through-12156
 12029       ERROR_INTERNET_CANNOT_CONNECT
               The attempt to connect to the server failed.
Make sure your server has access to the Internet - check your proxy and firewall settings.
