Filtering raster dataset in webapp
1922
06-26-2013 02:56 AM
DainiusTamosiunas
I have around 1000 rasters (b&w tiffs) and most of them overlay each other. At this moment, I'm holding them in mosaic dataset and I want them to be displayed in my javascript webapp. I am able to load it as Dynamic or Image service layer and it loads all the rasters at once. In screenshot below, mosaic's attribute table has field "Name" in which names of all the rasters are held (all names are unique to only one raster). In my webapp, I want to dynamically show only one raster by specifying its name.
Part of mosaic: http://i.imgur.com/RB2zl52.jpg
In arcmap I can use layer's definition query to select only particular raster (screenshot below).
Filtered by definition query: http://i.imgur.com/XDkFl8y.jpg
What would be the appropriate approach to have dataset filtered in webapp?
DainiusTamosiunas
I've found the answer: http://gis.stackexchange.com/questions/64477/arcgis-javascript-api-filter-raster-dataset
var mr = new esri.layers.MosaicRule(); mr.method = esri.layers.MosaicRule.METHOD_CENTER; mr.ascending = true; mr.operation = esri.layers.MosaicRule.OPERATION_FIRST; mr.where = "NAME = '" + rasterName + "'";  ArcGISImageServiceLayer.setMosaicRule(mr)
DainiusTamosiunas
YangLiu2
I have the same question. We have more than 200 raster datasets. Right now, I add them into one mosaic dataset and publish the mosaic dataset as image service. My clients want to access to mosaic attribute table and to query and filter based on the mosaic attibute table so that only the raster dataset they want can be shown. Do you have any suggestion or new found? Thanks!
-YL
