Artemis, thank you for providing an example to extract data.
However, that example does not use the ExtractData widget. Instead, it uses a Geoprocessor and then builds around it.
Is it possible to use this widget with a GP Service, locally hosted on Arcgis Server? If so, how should the service be set up in order to be compatible with the widget?
