Delete Multiple Graphic
783
11-16-2014 08:56 AM
JerryGarcia
I am trying to delete all graphics within a polygon, but the following code only removes the first graphic.  Any suggestions?
fieldGeom is a valid polygon.  It removes one point graphic, but then exits loop and does not remove a second point graphic.
Thanks!
        this.pointGraphics.graphics.forEach(function (g) {
            for (var x = 0; x < fieldIds.length; x++) {
                fieldGeom = that.getFieldGeometry(fieldIds);
                if (fieldGeom.contains(g.geometry) === true) {
                    that.pointGraphics.remove(g);
RobertScheitlin__GISP
Jerry,
  When looping though an array to delete objects from that array you always need to loop in reverse.
        for (var d = this.pointGraphics.graphics.length - 1; d-- >= 0;) {
            var dpnt = this.pointGraphics.graphics;
                if (fieldGeom.contains(dpnt.geometry) === true) {
                    that.pointGraphics.remove(dpnt);
Jerry,
