Here is the code. We are using a MVVM model with KnockoutJS
popupV.js:
(function() {
'use strict';
define(['gcviz-vm-datagrid'
], function(datagridVM) {
var initialize;
initialize = function($mapElem) {
var $popup,
popupWindow,
config = $mapElem.datagrid,
mapid = $mapElem.mapframe.id;
$mapElem.find('#' + mapid).append('<div id="popup' + mapid + '" class="gcviz-popup"></div>');
$popup = $mapElem.find('.gcviz-popup');
return(datagridVM.initialize($popup, mapid, config));
return {
initialize: initialize
}).call(this);
popupVM.js:
(function() {
'use strict';
define(['knockout',
'gcviz-i18n',
'gcviz-func',
'gcviz-gismap'
], function(ko, i18n, gcvizFunc, gisMap) {
var initialize,
vm;
initialize = function($mapElem, mapid, config) {
// data model
var datagridViewModel = function($mapElem, mapid, config) {
var _self = this,
layerInfo = config.layers,
popupid = 'popup' + mapid;
_self.init = function() {
var mymap = gcvizFunc.getElemValueVM(mapid, ['map', 'map'], 'js');
if (config.enable) {
// Are popups desired?
for (var i=0; i < layerInfo.length; i++) {
if (layerInfo.popups) {
gisMap.addPopup(mymap, layerInfo);
return { controlsDescendantBindings: true };
_self.clickPrevious = function() { //to be coded later };
_self.clickNext = function() { //to be coded later };
_self.init();
vm = new datagridViewModel($mapElem, mapid, config);
ko.applyBindings(vm, $mapElem[0]); // This makes Knockout get to work
return vm;
return {
}).call(this);
addPopup function inside gisMap module referenced inside popupVM:
addPopup = function(mymap, layerInfo) {
var fill = new esriFill('solid', null, new esriColor('#A4CE67')),
i,
layer,
thedescription,
template,
thetitle,
popup = new esriPopup({
fillSymbol: fill,
titleInBody: true
}, domConstruct.create('div'));
//Add the dark theme
domClass.add(popup.domNode, 'dark');
//Hide the maximize button
domClass.add(popup.domNode.childNodes[0].childNodes[0].childNodes[0].childNodes[4], 'hidden');
//Add popup to map
mymap.infoWindow = popup;
if (layerInfo.popups.title.usefield) {
thetitle = '{' + layerInfo.popups.title.titlefield + '}';
} else {
thetitle = layerInfo.popups.title.titletext;
//Put the desired fields in the content description
thedescription = '<table style=\"text-align: left;\">';
//TODO: Add it i18...
thedescription += '<tr><th>Property</th><th>Value</th></tr>';
for (i=0; i < layerInfo.popups.fields.length; i++) {
thedescription +='<tr>';
thedescription += '<td>' + layerInfo.popups.fields.fieldlabel + ':</td>';
thedescription += '<td>{' + layerInfo.popups.fields.fieldname + '}</td>';
thedescription +='</tr>';
thedescription += '</table>';
//Setup the template
template = new esriPopupTemplate({
title: thetitle,
description: thedescription
//Attach the template to the layer
//Check if in feature layers
for (i=0; i < mymap.layerIds.length; i++) {
layer = mymap.getLayer(mymap.layerIds);
if (layer.id === layerInfo.layerid) {
layer.infoTemplate = template;
//Check if in a GraphicLayer
for (i=0; i < mymap.graphicsLayerIds.length; i++) {
layer = mymap.getLayer(mymap.graphicsLayerIds);
popup.css:
@import "gcviz-mixin";
.gcviz-popup {
width: 350px!important;
height: 200px!important;
.infowindow {
/* Change color of icons in Popups */
.esriPopup.dark div.titleButton,
.esriPopup.dark div.titlePane .title {
color: $white!important;
.esriPopup.dark .titlePane {
background-color: $black;
background-image: url("http://s-bsc-geoappint.nrn.nrcan.gc.ca/GeoCanViz/gcviz/images/headBlackbar.png")!important;
.esriPopup.dark .actionsPane {
color: $black!important;
background-color: $palegrey;
background-image: url("http://s-bsc-geoappint.nrn.nrcan.gc.ca/GeoCanViz/gcviz/images/footGreybar.png")!important;
.esriPopup.dark .action {
.esriPopup.dark .titlePane, .dj_ie7 .esriPopup.dark .titlePane .title, .esriPopup.dark .contentPane, .esriPopup.dark .actionsPane {
.esriPopup.dark .sizer {
/* Additional customizations */
.esriPopup.dark .esriPopupWrapper {
border: none!important;
.esriPopup .contentPane {
text-align: center!important;
background-color: $white!important;
max-height: 150px!important;
@include app-text(1.0, bold, $black);
width: 325px!important;
.esriViewPopup .gallery {
margin: 0 auto!important;
.esriPopup {
z-index: 999999!important;
