Close Dialog Popup on Hyperlink Click
1572
13
08-10-2017 12:29 PM
deleted-user-1_r2dgYuILKY
I have a dialog popup with a hyperlink. I want the popup to close when the link is clicked. I've tried "nboLink.on("click", closeDialog);" but the console says that this is not a function. Here is my code:
Layer.on("click", function(evt){
            var name = evt.graphic.attributes.NAME;
            var nameNoDot = name.replace(/\./g,"");
            var nameDash = nameNoDot.replace(/_/g, "-");
            var nameLower = nameDash.toLowerCase();
          var nboLink = "<b>${NAME}</b><hr><a target='_blank' href='http://website/profiles/" + nameLower +
              "'><b>Profile</b></a>";
          var popupContent = esriLang.substitute(evt.graphic.attributes,nboLink);
          dialog.setContent(popupContent);
          domStyle.set(dialog.domNode, "opacity", 0.70);
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY,
          function closeDialog(){
               map.graphics.clear();
               dijitPopup.close(dialog);
RobertScheitlin__GISP
Levi,
   Here is your code working. Your issue was you were recreating the TooltipDialog digit multiple time based on its placement in your code and the on function had to be after the TooltipDialog was opened so that the dom.byId could find the anchor tag:
dialog<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Neighborhood Pulse</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.21/dijit/themes/claro/claro.css" />
  <link rel="stylesheet" href="https://js.arcgis.com/3.21/esri/css/esri.css" />
  <link rel="stylesheet" href="https://fonts.googleapis.com/css?family=Open Sans">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
      font-family: "Open Sans";
    #leftPane {
      background-color: whitesmoke;
      width: 20%;
      border: solid 1px #000;
    #photoPane {
      width: 20%;
      border: solid 1px #000; //bottom: 700px;
      height: 65%;
    #map {
      padding: 0;
    .nav {
      padding: 5px 10px;
      background: #4479BA;
      color: #FFF;
      border-radius: 5px;
      border: solid 1px #20538D;
      text-shadow: 0 -1px 0 rgba(0, 0, 0, 0.4);
      -webkit-box-shadow: inset 0 1px 0 rgba(255, 255, 255, 0.4), 0 1px 1px rgba(0, 0, 0, 0.2);
      -moz-box-shadow: inset 0 1px 0 rgba(255, 255, 255, 0.4), 0 1px 1px rgba(0, 0, 0, 0.2);
    #header {
      text-align: center;
      height: 8%;
      font-size: 19;
    #HomeButton {
      position: absolute;
      top: 95px;
      left: 245px;
      z-index: 50;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 290px;
    .dijitDialogPaneContent {
      width: 200px !important;
      height: 100px !important;
  </style>
  <script src="https://js.arcgis.com/3.21/"></script>
  <script>
    var map, timer;
    require([
      "esri/lang",
      "dojo/on",
      "dojo/dom",
      "dijit/registry",
      "dojo/dom-construct",
      "dojo/dom-style",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "esri/layers/FeatureLayer",
      "esri/dijit/PopupTemplate",
      "esri/dijit/HomeButton",
      "esri/dijit/Search",
      "esri/dijit/BasemapGallery",
      "esri/graphic",
      "dijit/layout/ContentPane",
      "esri/map",
      "esri/arcgis/utils",
      "esri/domUtils",
      "dijit/TooltipDialog",
      "esri/dijit/Popup",
      "dijit/popup",
      "dijit/Dialog",
      "dojo/domReady!"
    ], function(
      esriLang,
      on,
      dom,
      registry,
      domConstruct,
      domStyle,
      parser,
      BorderContainer,
      FeatureLayer,
      PopupTemplate,
      HomeButton,
      Search,
      BasemapGallery,
      Graphic,
      ContentPane,
      Map,
      arcgisUtils,
      domUtils,
      TooltipDialog,
      Popup,
      dijitPopup,
      Dialog
      parser.parse();
      map = new Map("map", {
        showLabels: false,
        basemap: "gray",
        center: [-122.650, 45.52],
        zoom: 11
      var home = new HomeButton({
        map: map
      }, "HomeButton");
      home.startup();
      var search = new Search({
        map: map,
        showInfoWindowOnSelect: false,
        enableLabel: false,
        enableHighlight: false
      }, "search");
      search.startup();
      var template = new PopupTemplate({
        title: "{NAME}",
        description: "<b>White Population</b>: {WhiteAlone_not_Hisp}" +
          "<br><b>Total Population 2010</b>: {TotPOP_2010}" +
          "<br><b>Neighborhood Coalition</b>: {LABEL_NAME_COALITION}"
      var neighborhoodsLayer = new FeatureLayer(
        "http://arcgis.research.pdx.edu/arcgis/rest/services/IMS_Services/Neighborhoods_Complete_nolabels/Map...", {
          infoTemplate: template,
          outFields: ["*"],
          maxScale: 0,
          minScale: 0,
          opacity: .60
      map.addLayer(neighborhoodsLayer);
      on(neighborhoodsLayer, "mouse-over", function(evt) {
        clearTimeout(timer);
        displayPopupContent(evt.graphic);
      on(neighborhoodsLayer, "mouse-out", function(evt) {
        timer = setTimeout(function() {
          map.infoWindow.clearFeatures();
        }, 100)
      map.infoWindow.set("popupWindow", false);
      initializeSidebar(map);
      dialog  = new TooltipDialog({
        style: "position: absolute; width: 200px; font: normal normal normal 10pt Arial;z-index:100"
      function initializeSidebar(map) {
        var popup = map.infoWindow;
        //when the selection changes update the side panel to display the popup info for the
        //currently selected feature.
        on(popup, "selection-change", function() {
          displayPopupContent(popup.getSelectedFeature());
        //When features are associated with the  map's info window update the sidebar with the new content.
        on(popup, "set-features", function() {
      function displayPopupContent(feature) {
        if (feature) {
          var photoSRC = "https://images.trvl-media.com/media/content/shared/images/travelguides/destination/178299/Portland-2...";
          var photo = '<a><IMG SRC="' + photoSRC + '"width=200 height=125/></a>';
          var content = feature.getContent();
          registry.byId("leftPane").set("content", content, photo);
          registry.byId("photoPane").set("content", photo);
        neighborhoodsLayer.on("click", function(evt) {
          var nameNoDot = name.replace(/\./g, "");
          var nboLink = "<b>${NAME}</b><hr><a id='myLink' target='_blank' href='http://neighborhoodpulsepdx.org/profiles/" + nameLower +
          var popupContent = esriLang.substitute(evt.graphic.attributes, nboLink);
          dialog .setContent(popupContent);
          domStyle.set(dialog .domNode, "opacity", 0.70);
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
          on(dom.byId("myLink"),"click", closeDialog);
          function closeDialog () {
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="gutters:false" region="left" style="width:225px;height:100%;font-size:13;">
      <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
      <div id="photoPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'"></div>
      <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="width:200px;height:10%;">
        <div id="featureCount" style="margin-bottom:10px;"><b>Portland<br>Neighborhoods</b></div>
      </div>
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
    <div id="search"></div>
    <span id="info" style="font-family:arial;position:absolute;left:250px; bottom:5px; background-color:lightgray; opacity: 0.70; z-index:50;"></span>
    <div id="HomeButton"></div>
    <div style="position:absolute; left:250px; bottom:40px; z-Index:999;">
    </div>
</body>
</html>
Levi,
Have you tried just adding an onClick to your anchor element?
var nboLink = "<b>${NAME}</b><hr><a target='_blank' onClick='closeDialog' href='http://website/profiles/" + nameLower +
I added that and got this error in the console: "closeDialog is not defined at HTMLAnchorElement.onclick." I tried moving the closeDialog() function definition before the nboLink and got the same error.
Levi,
   That sounds like a scope issue then. Try this:
          var nboLink = "<b>${NAME}</b><hr><a id='myLink' target='_blank' href='http://website/profiles/" + nameLower +
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY,
OK. I tired that and got this error: Cannot read property 'on' of null.
Levi can you provide a complete sample of this issue?
Here's the whole script:
<head>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #leftPane {
      width: 20%;
     #photoPane {
      width: 20%;
       //bottom: 700px;
       height: 65%;
    #map {
      padding: 0;
    .nav {
      padding: 5px 10px;
      color: #FFF;
      border-radius: 5px;
    #header {
      text-align: center;
      height: 8%;
       font-size: 19;
     #HomeButton {
      position: absolute;
      top: 95px;
      left: 245px;
      z-index: 50;
     #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 290px;
  </style>
  <script>
    var map, timer;
    require([
      "esri/lang",
      "dojo/on",
      "dojo/dom",
      "dijit/registry",
      "dojo/dom-style",
      "dojo/parser",
       "esri/graphic",
      "esri/map",
      "esri/domUtils",
      "esri/dijit/Popup",
      "dijit/popup",
      "dijit/Dialog",
      "dojo/domReady!"
    ], function(
      esriLang,
      on,
      dom,
      registry,
      domConstruct,
      domStyle,
      parser,
      BorderContainer,
      FeatureLayer,
      PopupTemplate,
       HomeButton,
       Search,
       BasemapGallery,
       Graphic,
      ContentPane,
      Map,
      arcgisUtils,
      domUtils,
       TooltipDialog,
      Popup,
      dijitPopup,
      Dialog
      parser.parse();
        showLabels: false,
        basemap: "gray",
        zoom: 11
          map: map
         }, "HomeButton");
         home.startup();
            map: map,
               enableLabel: false,
         }, "search");
         search.startup();
        title: "{NAME}",
          outFields: ["*"],
            maxScale: 0,
            minScale: 0,
            opacity: .60
        }, 100)
      function displayPopupContent(feature){
        if (feature) {
          registry.byId("leftPane").set("content",content,photo);
            registry.byId("photoPane").set("content",photo);
          neighborhoodsLayer.on("click", function(evt){
          //on(dom.byId("myLink"),"click", closeDialog);
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY,
  </script>
</head>
      <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style= "width:200px;height:10%;">
      </div>
    </div>
  </div>
</body>
</html>
Levi,
<html>
<head>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #leftPane {
      width: 20%;
    #photoPane {
      width: 20%;
      height: 65%;
    #map {
      padding: 0;
    .nav {
      padding: 5px 10px;
      color: #FFF;
      border-radius: 5px;
    #header {
      text-align: center;
      height: 8%;
      font-size: 19;
    #HomeButton {
      position: absolute;
      top: 95px;
      left: 245px;
      z-index: 50;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 290px;
  </style>
  <script>
    var map, timer;
    require([
      "esri/lang",
      "dojo/on",
      "dojo/dom",
      "dijit/registry",
      "dojo/dom-style",
      "dojo/parser",
      "esri/graphic",
      "esri/map",
      "esri/domUtils",
      "esri/dijit/Popup",
      "dijit/popup",
      "dijit/Dialog",
      "dojo/domReady!"
    ], function(
      esriLang,
      on,
      dom,
      registry,
      domConstruct,
      domStyle,
      parser,
      BorderContainer,
      FeatureLayer,
      PopupTemplate,
      HomeButton,
      Search,
      BasemapGallery,
      Graphic,
      ContentPane,
      Map,
      arcgisUtils,
      domUtils,
      TooltipDialog,
      Popup,
      dijitPopup,
      Dialog
      parser.parse();
        showLabels: false,
        basemap: "gray",
        zoom: 11
        map: map
      }, "HomeButton");
      home.startup();
        map: map,
        enableLabel: false,
      }, "search");
      search.startup();
        title: "{NAME}",
          outFields: ["*"],
          maxScale: 0,
          minScale: 0,
          opacity: .60
        }, 100)
        if (feature) {
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
  </script>
</head>
      </div>
    </div>
    </div>
</body>
</html>
Thanks Robert!
KenBuja
Nice reply, Robert.
I have one question about adding the event. Since you're adding this event every time the layer is clicked, would this be a potential memory leak? Would it be better to fire that event just once?
on.once(dom.byId("myLink"),"click", closeDialog);
