Solved with the help of ESRI Services...
Set the Source on the New Feature layer to that of graphicsLayer.graphics
I then make sure that I add that New Feature Layer after the code is run to populate the graphics layer.
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Query features from a FeatureLayer | Sample | ArcGIS API for JavaScript 4.19</title>
<script>
var dojoConfig = {
has: {
"esri-featurelayer-webgl": 1
</script>
<link rel="stylesheet" href="https://js.arcgis.com/4.19/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.19/"></script>
<style>
#container {
width: 100%;
height: 100%;
position: relative;
#viewDiv {
width: 100%;
height: 100%;
position: absolute;
top: 0;
left: 0;
#infoDiv {
background-color: white;
color: black;
padding: 6px;
width: 400px;
#results {
font-weight: bolder;
padding-top: 10px;
#drop-downs{
padding-bottom: 15px;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/layers/GraphicsLayer",
"esri/geometry/geometryEngine",
"esri/Graphic",
"esri/widgets/Slider",
"esri/symbols/SimpleFillSymbol",
"esri/PopupTemplate",
"esri/renderers/ClassBreaksRenderer",
"esri/renderers/SimpleRenderer"
], function(Map, MapView, FeatureLayer, GraphicsLayer,
geometryEngine, Graphic, Slider,
SimpleFillSymbol, PopupTemplate, ClassBreaksRenderer, SimpleRenderer)
var wellBuffer, wellsGeometries, magnitude;
var wellTypeSelect = document.getElementById("well-type");
var pointsUrl ="https://xxxx/arcgis/rest/services/Test/Test/FeatureServer/0";
// historic earthquakes
var pointsLayer = new FeatureLayer({
url: pointsUrl,
outFields: ["*"],
minScale: 400000,
visible: false,
popupTemplate: template
var polygonUrl ="https://xxxx/arcgis/rest/services/Test/Test/FeatureServer/1";
var polygonLayer = new FeatureLayer({
url: polygonUrl,
outFields: ["*"],
visible: false
// GraphicsLayer for displaying results
var resultsPolygonLayer2 = new GraphicsLayer({
var less1 = new SimpleFillSymbol({
color: "gray",
style: "none",
opacity: .5,
outline: {
width: 0.1,
color: "gray"
var moreseventy = new SimpleFillSymbol({
color: "Blue",
style: "solid",
opacity: .5,
outline: {
width: 0.1,
color: "gray"
var fieldChoosen = "";
fieldChoosen = "Field 1";
var rendererPolygon = new ClassBreaksRenderer({
field: fieldChoosen,
//normalizationField: "EDUCBASECY",
defaultSymbol: new SimpleFillSymbol({
color: "red",
outline: {
width: 0.5,
color: "white"
defaultLabel: "no data",
classBreakInfos: [
minValue: 0,
maxValue: 0.9,
symbol: less1,
label: "< 1"
minValue: 70.01,
maxValue: 200.00,
symbol: moreseventy,
label: "> 70"
// create empty FeatureLayer
const monumentLayer = new FeatureLayer({
// create an instance of esri/layers/support/Field for each field object
title: "",
fields: [
alias: "ObjectID",
type: "oid"
alias: "Field 1",
type: "string"
objectIdField: "OBJECTID",
geometryType: "polygon",
spatialReference: { wkid: 3857 },
source: resultsPolygonLayer2.graphics,
renderer: rendererPolygon,
popupTemplate: {
title: "{OBJECTID}"
// SET THE MIN MAX SCALE TO TURN GRAPHICS LAYERS ON AND OFF BASED ON ZOOM
resultsPolygonLayer2.minScale = 400000;
var map = new Map({
basemap: "dark-gray-vector",
layers: [pointsLayer, polygonLayer, resultsPolygonLayer2]
var view = new MapView({
container: "viewDiv",
map: map,
center: [-78.989586, 37.566286],
zoom: 6
view.ui.add("infoDiv", "top-right");
// query all features from the points layer
view
.when(function() {
return pointsLayer.when(function() {
var query = pointsLayer.createQuery();
return pointsLayer.queryFeatures(query);
.then(getValues)
.then(getUniqueValues)
.then(addToSelect)
.then(createBuffer);
function getValues(response) {
var features = response.features;
var values = features.map(function(feature) {
return feature.attributes.common_name;
return values;
// return an array of unique values in
// the STATUS2 field of the wells layer
function getUniqueValues(values) {
var uniqueValues = [];
uniqueValues.push("A Select Species");
values.forEach(function(item, i) {
if ((uniqueValues.length < 1 || uniqueValues.indexOf(item) === -1) && item !== "") {
uniqueValues.push(item);
uniqueValues.sort();
return uniqueValues;
function addToSelect(values) {
values.sort();
values.forEach(function(value) {
var option = document.createElement("option");
option.text = value;
wellTypeSelect.add(option);
return setWellsDefinitionExpression(wellTypeSelect.value);
// set the definition expression on the wells
// layer to reflect the selection of the user
function setWellsDefinitionExpression(newValue) {
pointsLayer.definitionExpression = "common_name = '" + newValue + "'";
if (!pointsLayer.visible) {
pointsLayer.visible = true;
return queryForWellGeometries();
// Get all the geometries of the wells layer
// the createQuery() method creates a query
// object that respects the definitionExpression
// of the layer
function queryForWellGeometries() {
var pointsQuery = pointsLayer.createQuery();
return pointsLayer.queryFeatures(pointsQuery).then(function(response) {
pointsGeometries = response.features.map(function(feature) {
return feature.geometry;
return pointsGeometries;
var bufferGraphic = null;
function createBuffer(wellPoints) {
//var bufferDistance = distanceSlider.values[0];
var bufferDistance = 1;
var wellBuffers = geometryEngine.geodesicBuffer(wellPoints, [bufferDistance], "meters", true);
wellBuffer = wellBuffers[0];
queryPolygons2().then(displayResults2);
zoompolygons();
function zoompolygons(){
// ZOOM TO THE RETURNED FEATURES
let opts = {
duration: 5000 // Duration of animation will be 5 seconds
pointsLayer.queryExtent().then((response) => {
// go to the extent of all the graphics in the layer view
view.goTo({
target: (response.extent.clone().expand(1.0112))
}, opts);
monumentLayer.refresh();
// set a new definitionExpression on the wells layer
// and create a new buffer around the new wells
wellTypeSelect.addEventListener("change", function() {
var type = event.target.value;
setWellsDefinitionExpression(type).then(createBuffer);
map.remove(monumentLayer);
function queryPolygons2() {
var query = polygonLayer.createQuery();
query.geometry = wellBuffer;
query.spatialRelationship = "intersects";
return polygonLayer.queryFeatures(query);
// display the earthquake query results in the
// view and print the number of results to the DOM
function displayResults2(results) {
resultsPolygonLayer2.removeAll();
var features = results.features.map(function(graphic) {
graphic.symbol = {
type: "simple-fill", // autocasts as new SimpleMarkerSymbol()
style: "none",
outline: { // autocasts as new SimpleLineSymbol()
color: "gray",
width: 1
opacity: .5,
color: [ 51,51, 204, 0.9 ]
return graphic;
var numPolygons = features.length;
document.getElementById("results").innerHTML = numPolygons + " grids found";
resultsPolygonLayer2.addMany(features);
// SET THE SOURCE OF THE GRAPHICS LAYER TO THE MONUMENT LAYER
monumentLayer.source = resultsPolygonLayer2.graphics;
// ADD THE MONUMNET LAYER TO THE MAP
map.add(monumentLayer);
}); // END OF MAIN FUNCTION
</script>
</head>
<body>
<div id="container">
<div id="viewDiv"></div>
<div id="infoDiv" class="esri-widget">
<div id="drop-downs">
Select Species type:
<select id="well-type" class="esri-widget"></select>
</div>
<div id="results" class="esri-widget"></div>
</div>
</div>
</body>
</html>
