Change Color and size of polygon vertex
1062
5
03-16-2020 09:03 PM
rsharma
Hi want to change color and size of vertex of polygon
RobertScheitlin__GISP
Rajni,
   No one is answering because this is not something that you can do currently in the API. As Egge-Jan states the vertices symbol is controlled inside the API and no property is provided to change it.
Egge-Jan_Pollé
MVP Regular Contributor
Hi rajni sharma,
This is the same question as the one you posted last week, isn't it? Change Style of vertices points
You are referring to the vertices of polylines or polygons drawn with the Editor widget, I guess? Editor widget with configurations | ArcGIS API for JavaScript 4.14
Hmmm. I suppose this color and size is defined somewhere deep down in the underlying CSS. Would not know how to change it. Sorry 🙂
But then, why would you want to change these? It is a nice piece of UI/UX, well designed and well implemented. I would leave it as-is if I were you...
Hope you will find an answer to your question.
BR,
Egge-Jan
rsharma
Hi Egge,
Yes you are right i have already posted the same question twice but no answer received from anyone. I want to change the color and size because its the demand of my project.
I am not using any editor widget, instead i am creating my own symbol of polygon like below:
function createSymbol(color, style, width, outlineColor) {
          return {
            type: "simple-fill",
            style: style,
            color: color,
            outline: {
              color: outlineColor,
              width: width,
              style: "dash"
        }//End createSymbol
Rajni,
rsharma
ok sir
MarkoPolo
Well that is just poor API design isn't it. What a joke.
