Can't access dynamic layer from outside the company
741
04-28-2010 06:20 AM
JacobRaymond
I'm very new to ArcGIS Server and scripting and am having some trouble with accessing a dynamic layer from outside the company.  The script below works fine when I am within the company, but I am trying to give someone access to these services from the outside and only the tiled map service works.  The guy tells me that through debugging he can see that the service is still trying to hit gisweb at some point instead of gisweb.XXX.com to access the service.  Again, the tiled layer works so it's not a permissions thing or anything.  Has anyone ever experienced this at all or know where to start looking for the problem?  I'm guessing it's something in the configuration but I have no idea what.
Jacob
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns:v="urn:schemas-microsoft-com:vml" xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <title>Add Spot5 to Google Maps</title>
    <script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABC"></script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/gmaps/?v=1.6"></script>
    <script type="text/javascript">
    var gmap = null;
    var mapExtension;
    var gOverlays = null;
    var dynMapOv = null;
function initialize() {
      //Load Google Maps
      gmap = new GMap2(document.getElementById("gmap"));
      var centerat = new GLatLng(0, 0);
      gmap.addControl(new GLargeMapControl());
      gmap.addControl(new GMapTypeControl());
      gmap.setCenter(centerat, 1);
      gmap.enableScrollWheelZoom();
      //create mapextension class to be used to add/remove results from the map.
      mapExtension = new esri.arcgis.gmaps.MapExtension(gmap);
      //create mapOptions to specify opacity, minResolution, maxResolution when adding to the map.
      var mapOptions = {opacity: 0.75, minResolution:0, maxResolution: 19};
     //create custom tile layer
      var tiledmap = new esri.arcgis.gmaps.TiledMapServiceLayer
         ("http://gisweb.XXXX.com/ArcGIS/rest/services/6515_Consultation/SPOT5_WebMercator/MapServer",
         mapOptions, addTiledMap);
     //create custom dynamic layer
     //esri.arcgis.gmaps.DynamicMapServiceLayer(url,esri.arcgis.gmaps.ImageParameters?,opacity?,callback?);
      var dynamicMap = new esri.arcgis.gmaps.DynamicMapServiceLayer
        ("http://gisweb.XXXX.com/ArcGIS/rest/services/6515_Consultation/Routing_WebMercator/MapServer",
        null, 0.75, dynmapcallback);
function addTiledMap(gTileLayer) {
      //Add tile layer as a GTileLayerOverlay using mapExtension
      gOverlays = mapExtension.addToMap(gTileLayer);
function dynmapcallback(groundov) {
      //Add groundoverlay to map using gmap.addOverlay()
      gmap.addOverlay(groundov);
      dynMapOv = groundov;
    </script>
    </head>
  <body>
    <body onunload="GUnload();" onload="initialize();">
    <div style="width: 500px; height:500px;" id="gmap"></div>
  </body>
</html>
JacobRaymond
It turns out is was a simple problem.  I just had to go into Manager and change the server directories.   When my IT dept opened our server up to the outside I didn't realize that I had to change the url in the server directories, so it was trying to access gisweb/arcgisoutput directory instead of gisweb.abscerver.com/arcgisoutput directory.
