ArcGIS API 4.19 Dojo build failure
1276
05-03-2021 06:43 PM
JimmyWang
Hello:
I am working on ArcGIS API 4.19 Dojo build up. When I ran "npm run build", It was fail. I checked log file. I got a error following:
error(356) The optimizer threw an exception; the module probably contains syntax errors.
module identifier: E:\TJPort\grid\jsapi-resources\4.x\amd\dojo\dist\esri\views\2d\layers\FeatureLayerView2D.js; exception: (compile time:0.245s). OPTIMIZER FAILED: JavaException: java.lang.NullPointerException: NAME NaN 127 [length: 6] [source_file: FeatureLayerView2D.js.uncompressed.js]
Can you supply any idea to fixe this one ?
Thanks
Jimmy
ReneRubalcava
Honored Contributor
Hi there!
Can you update the dojo-util to use our fork please.
  "devDependencies": {
    "dojo-util": "git+https://github.com/Esri/dojo-util.git#1.16.3-esri",
We use an updated version of the closure compiler that will fix this issue for dojo builds.
Thanks!
JethroLeevers
I also have this issue, that file seems to have some really long lines in it.
ReneRubalcava
Honored Contributor
Hi there!
Thanks!
JimmyWang
Thanks for your solution. Now it is working.
Thanks
Jimmy
