Hi, I have already shared a point map through ArcGIS server and added as a feature layer to my Map. How can I add a created point graphics as a real point to the feature layer. Note that the feature layer is in a SQL server Geo-database and registered as versioned.
Solved! Go to Solution.
I have just shared a geo-processing service and update my geo-database in the SQL server. look at Run Geo-processing Service.
I suppose you could use AplyEdits: FeatureLayer (legacy) | API Reference | ArcGIS API for JavaScript 3.22 or post it directly using the REST API: ArcGIS Server REST API
See also discussion here: https://community.esri.com/thread/77916
Dear Xander,
Could you please take a look at the new question (i.e. Updating Geo-Database, posted in November 29) that relates to this question?
Thank you so much
