WMS API javascript 4.15
612
05-12-2020 12:00 AM
deleted-user-VQ40NmU7Vt6N
New Contributor II
I have a problem with public NASA layer wms, this is my simple code:
    <script>
        require(["esri/Map","esri/views/MapView","esri/layers/WMSLayer"],
      function(MapMapView,WMSLayer) {
                var map = new Map({
                    basemap: "streets-navigation-vector"
                var view = new MapView({
                    container: "viewDiv",
                    map: map,
                    center: [-118.8050034.02700], // longitude, latitude
                    zoom: 13
                var layer = new WMSLayer({
                      url: "https://firms.modaps.eosdis.nasa.gov/wms",
                      sublayers: [{
              map.add(layer);
        </script>
And this is the console error: Access to fetch at 'https://firms.modaps.eosdis.nasa.gov/wms?SERVICE=WMS&REQUEST=GetCapabilities' from origin 'null' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
I DO NOT UNDERSTAND THIS ERROR BECAUSE I CAN USE THIS WMS IN OPENLAYERS EASILY WITHOUT ERROR.
IS THERE ANY SIMPLE CODE TO FIX THIS?
Thanks!!
GeofyAdmin
New Contributor III
This is your web browser basically acting as designed: you can load your app from domain1 and reach out to domain2. It’s a security thing..
To temporarily disable such behavior, just to see that your code works, you can use chrome by running it from the command line like this:
chrome.exe —disable-web-security —user-data-dir=c:\temp
then open your app.
For a more permanent solution you need to configure your web server where your app is deployed to allow cors.
There is also the proxy option, where you place a proxy app on the server to route all calls; that way your client only talks to your webserver so you avoid cors altogether.
GeofyAdmin
New Contributor III
then open your app.
