I have a left-hand panel with project info cards and a map taking up the rest of the page with polygons of project locations. I've gotten it to the point where when I hover over a card, its corresponding polygon gets highlighted, but the dialog with the project title is not showing up. I can't figure out why. When I console log 'content' I get the correct title and it seems like I get output when I console.log 'dialog' as well, but I'm not getting a pop up on the map. Any help would be greatly appreciated!
Thanks!
Here's my code:
require([
"esri/map",
"esri/layers/FeatureLayer",
// "esri/dijit/PopupTemplate",
// "esri/InfoTemplate",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/renderers/SimpleRenderer",
"esri/graphic",
"esri/lang",
"esri/Color",
"dojo/number",
"dojo/dom-style",
"dijit/TooltipDialog",
"dijit/popup",
"esri/dijit/Legend",
"dojo/_base/array",
"esri/tasks/query",
"esri/tasks/QueryTask",
"dojo/on",
"dojo/dom",
"dojo/dom-construct",
"dojo/domReady!"
], function(
Map,
FeatureLayer,
SimpleFillSymbol,
SimpleLineSymbol,
SimpleRenderer,
Graphic,
esriLang,
Color,
number,
domStyle,
TooltipDialog,
dijitPopup,
Legend,
array,
Query,
QueryTask,
on,
dom,
domConst
var map = new Map("viewDiv", {
basemap: "gray-vector",
center: [ -85.20127, 35.12355 ],
zoom: 1
//Add layer to the map
var serviceUrl = "https://services2.arcgis.com/C8EMgrsFcRFL6LrL/arcgis/rest/services/HISAProjects_WFL1/FeatureServer/0... ";
var layer = new FeatureLayer(serviceUrl, {
mode: FeatureLayer.MODE_SNAPSHOT,
outFields: [ "FY", "HISAProjects_final_1262017_cs_2", "HISAProjects_final_1262017_csv1", "HISAProjects_final_1262017_cs_4", "HISAProjects_final_1262017_cs_5", "HISAProjects_final_1262017_csv_", "HISAProjects_final_1262017_cs_3", "HISAProjects_final_1262017_cs_1", "HabitatData12_4_17_ProjectNum"],
map.addLayer(layer);
// "Global" Variables
var button = document.getElementById("button");
var idValues = [];
var elem = document.getElementsByClassName("clickable");
//var projNumArr = [];
var target;
map.infoWindow.resize(245,125);
//close the dialog when the mouse leaves the highlight graphic
map.on("load", function(){
//load map
map.graphics.enableMouseEvents();
map.graphics.on("mouse-out", closeDialog);
closeDialog();
dialog = new TooltipDialog({
style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100"
dialog.startup();
var highlightSymbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([255,0,0]), 3
new Color([125,125,125,0.35])
layer.on('update-end', function(evt){
var projectID = [];
array.map(layer.graphics, function(gra){
projectID.push(gra.attributes.HabitatData12_4_17_ProjectNum);
var project = projectID;
//Read id number for each card
$(".clickable").mouseenter(function(e) {
var target = $(this).attr("id");
var result = target.split(",");
console.log(result + ", " + typeof result); //id of card "selected"
project.forEach(function(id) {
if(id == result){
console.log("same: " + id);
var same = id;
console.log("same id: " + same);
if(same == gra.attributes.HabitatData12_4_17_ProjectNum){
var t = "<b>${HISAProjects_final_1262017_cs_4}</b>";
var content = esriLang.substitute(gra.attributes,t);
var highlightGraphic = new Graphic(gra.geometry, highlightSymbol);
map.graphics.add(highlightGraphic);
dialog.setContent(content);
domStyle.set(dialog.domNode, "opacity", 0.85);
dijitPopup.open({
popup: dialog,
x: evt.pageX,
y: evt.pageY
function closeDialog() {
map.graphics.clear();
dijitPopup.close(dialog);
$(".clickable").mouseleave(function(e) {
var legend = new Legend({
map: map,
layerInfos: [{
layer: layer,
title: "Habitat Type"
}, "legendDiv");
map.on("load", function(evt){
legend.startup();
}); // end Function
Hi Robert, I'm returning to this part of my code. When I hover over my cards, the pop ups don't appear directly over my polygons so that you know the . It looks like the pop up is trying to appear directly in the middle between the card and the polygon which makes it hard to know which polygon it's referring to. I'm not sure how to adjust this feature. Is there a property that controls where the pop up appears? I'm having trouble finding resources for this particular question for v3.2
Thanks!
Cara,
The code looks like it should be using the graphics extent (bounding box) center. So in your image which graphic is this popup suppose to be for?
It's supposed to be for the polygon highlighted in gold in the Gulf of Mexico.
Cara,
Try:
dijitPopup.open({
popup: dialog,
x: map.toScreen(pCent).x + map.position.x,
y: map.toScreen(pCent).y + map.position.y
Hi Robert, ignore my last comment. I got mixed up. It works perfectly. Thank you so much for your time!
