Hi, I need help to create a csvlayer from a local csv file, I tried using "url = file:///c:/local_folder/local_file.csv", but it does not work, the reference said we can use either file or http protocol, what is the correct syntax for the url string to load csv file? Thank you.
William,
I don't think that using a file:// url is supported but you can see in the drag and drop sample you can use local csv files.
Drag and drop to display data | ArcGIS API for JavaScript 3.23
Robert, Thank you. I have to use the http protocol and it works when the csv file is located in the same website.
