What is the best way to select features from multiple layers in 4.x?
4088
03-08-2021 09:16 AM
MattStayner
I have a map that contains features services, map services and graphic layers. What is the best way to select multiple features from multiple layers? For example, I want a user to be able to select a point in a mass of features from multiple layers and cycle through the features in a custom side panel to find the feature they are interested in.
I tried using hitTest, but that only returns the first feature from each layer. Too bad.
I found this example for 3.x. Would this be the best approach in 4.x as well? Any chance I could get one of your awesome working codepen examples using 4.x?
Query and QuertyTask are kind of pain because the buffer needs to change based on the zoom level. I know the API is already accounting for that using hitTest and other methods. Are there any other approaches we should consider? For example, in 3.x, we used var popup = map.infoWindow and connect.connect(popup, "onSetFeatures", function() {}) to trigger the custom panel based on a click on the map. Is there an equivalent approach in 4.x?
MattStayner
The Esri widget Popup looks like it is what we are looking for. We will give it a try. Thanks!
jkumartry1980
Hi Matt,
Have you tried this option, I need solution for similar task. Could you please share the idea?
MattStayner
@jkumartry1980 Yes, I got it working, but it took a bit to get everything in place.
First, I added the popupTemplate to all the feature layers in my map
layerToAdd = new FeatureLayer(layer.service_url, {
  outFields: ['*'],
  popupTemplate: {}, // required to trigger info panel
  visible
Then I listened for a click on the view, and looked at all of the results:
this.view.on('click', async (event) => {
  // Use popup to select features on the map. Only features with popupTemplate enabled will be selected
  const resp = await view.popup.fetchFeatures(event)
  const results = await resp.allGraphicsPromise
  if (Array.isArray(results)) {
    if (results.length === 0) {
      this.$emit('pointer-clicked-outside')
      return
    const popupResults = results.filter((r) => {
      //do something with results, like highlight the selected feature
      await this.highlightItem(r)
Lastly, I highlighted the selected graphic
async highlightItem (gisInfo) {
    const { view } = this
    if (gisInfo.layer) {
      const layerView = await view.whenLayerView(gisInfo.layer)
      const selected = layerView.highlight(gisInfo)
      this.highlightSelect.push(selected)
    } else if (gisInfo?.sourceLayer?.layer) {
        gisInfo.sourceLayer.layer
I stripped out the code that wasn't applicable. I'm not sure if what I have above will work exactly as-is, but hopefully it gets you on the right track.
