For some reason I think this should be more straight forward. What we need to do is access a secure service on our ArcGIS Enterprise installation from a map built using the javascript API.
If I host the web application on the same server as the ArcGIS Enterprise installation, everything works without any issue. Do not even have to do anything with IdentityManager. Looking at fiddler I can see that the requests are challenged with a 401 response and then another call is made passing in the required Negotiate security header.
However, this is no longer the case when hosting the application on a different web server, also within the same domain. Looking at fiddler in this case the same initial 401 response, however, in these cases (I have tried a number of servers) the follow-up request with the Negotiate header is never sent.
I have tried too many things to even describe basically following numerous examples of how one would use IdentityManager to request credentials.
These all take the general form of
const server = portalUrl + '/sharing/rest';
const tokenServiceUrl = server + '/generateToken';
const serverInfo = {
tokenServiceUrl
const userInfo = {
username,
password
esriId.generateToken(serverInfo, userInfo).then((tokenInfo) => {
esriId.registerToken({tokenInfo, server})
}, (error) => {
console.log(error);
}).catch(() => {
console.log("hello");
In this case what is observed is that the request to the generateToken endpoint returns a 401 response but again the follow-up request with the Negotiate header is never sent.
I am at my wits end. Hosting the web application on the ArcGIS Enterprise server in our production environment is likely not possible so we need a way to do from a separate server
-Joe
