Using Geometry.fromJSON() gives unexpected results
1691
05-07-2020 07:42 AM
EricPaitz
I am trying to use Geometry.fromJSON() in the ArcGIS JSAPI 4.x to return a Point or an Extent geometry and I am getting some unexpected results.
Here is what I have tried.
const point = Geometry.fromJSON({x: 10, y: 10, spatialReference: {wkid: 4326}})
const point = Geometry.fromJSON({type: "point", x: 10, y: 10, spatialReference: {wkid: 4326}})
const point = Geometry.fromJSON(JSON.stringify({x: 10, y: 10, spatialReference: {wkid: 4326}}))
const point = Geometry.fromJSON({"x": 10, "y": 10, "spatialReference": {"wkid": 4326}})
const point = Geometry.fromJSON('{"x": 10, "y": 10, "spatialReference": {"wkid": 4326}}')
console.log(JSON.stringify(point.toJSON()))
Here is the result in the console.
{"spatialReference":{"wkid":4326}}
Should I be able to get a Point geometry with the JSON I am using with Geometry.fromJSON()?
My goal would be to do the following...
mapView.goTo(Geometry.fromJSON({....});
...using valid JSON for a Point or an Extent.
AnneFitz
Hi Eric, I would try using Point.fromJSON() instead.
EricPaitz
Anne,
Thank you for the reply. I did notice that worked, and I forgot to add that detail to my post. The JSON will be describing a point or an extent so I was hoping that Geomery.fromJSON() would be able to create a Point from point JSON and an Extent from extent JSON. Am I using Geometry.fromJSON() incorrectly?
