use popup template in searchwidget geocoder
1066
08-16-2017 02:53 AM
Henryobaseki
Hi All,
I do have a popup template that works in my search sources, however, would like to use the same template in the search default source, not able to so far.
I want to be able to have the same popup template in this code at the moment, its using a default template which works, but I want like to have a new popup template like the other sources. At the moment not able to any help please.
The function is to click on anywhere in the mapdiv and it returns addresses and x y coordinates as a popup
function showPopup(address, pt) {
    view.popup.open({
      title: "Find Address Result",
      content: address + "<br><br> Lat: " + Math.round(pt.latitude * 100000)/100000 + " Lon: " + Math.round(pt.longitude * 100000)/100000,
var search = new Search({
    view: view,
     activeSourceIndex:-1
  search.defaultSource.withinViewEnabled = false; // Limit search to visible map area only
  view.ui.add(search, "top-right"); // Add to the map
  // Add the trailheads as a search source
  search.sources.push({
    featureLayer: trailsLayer,
     searchFields: ["UPRN", "ADDRESS" ],
  displayField: "ADDRESS",
  exactMatch: false,
  outFields: ["*"],
   resultGraphicEnabled: true,
    name: "Chelmsford Addresses",
  placeholder: "example:  CM2 0HU",
    popupTemplate: { // autocasts as new popupTemplate()
        title: "Chelmsford Addresses",
          content: [{
            type: "fields",
            fieldInfos: [{
              fieldName: "UPRN"
              fieldName: "ADDRESS",
              fieldName: "LAT",
              fieldName: "LONG"
          actions: [{
            image: "beer.png",
           title: "Get XY Cordinates"
    featureLayer: trailsLayer2,
     searchFields:"LOCATION" ],
  displayField: "LOCATION",
  exactMatch: false,
  outFields: ["*"],
    name: "Chelmsford Car Parks",
      //  title: "Car Park </br>Location: {LOCATION}",
        title: "Chelmsford CarParks",
          content: [{
            type: "fields",
            fieldInfos: [{
              fieldName: "LOCATION"
              actions: [{
            image: "beer.png",
            title: "Get xy cordinates"
        //overwriteActions: true
    featureLayer: trailsLayer3,
     searchFields: ["WARD_N" ],
  displayField: "WARD_N",
  exactMatch: false,
  outFields: ["*"],
        title: "Post Code: {Postcode}</br>UPRN: {UPRN}</br>ADDRESS: {ADDRESS}",
  // Find address
    view.popup.open({
        actions: [{
            image: "beer.png",
  view.on("click", function(evt){
    search.clear();
    view.popup.clear();
    var locatorSource = search.defaultSource;
    locatorSource.locator.locationToAddress(evt.mapPoint)
      .then(function(response) {
        var address = response.address.Match_addr;
        // Show the address found
        showPopup(address, evt.mapPoint);
      }, function(err) {
        // Show no address found
        showPopup("No address found for this location.", evt.mapPoint);
Tags (1)
