Uncaught TypeError: Converting circular structure to JSON peinr
2878
03-24-2016 08:43 AM
WeiGao1
I am using print widget to print map, but receive this error "Uncaught TypeError: Converting circular structure to JSON"
Tags (1)
ChrisSmith7
Honored Contributor
Hi Wei,
I see this thread has been hanging out for a few months without a reply, so hopefully I'm not too late...
I recently encountered this myself and discovered a resolution. In my particular case, I had a dojox datagrid embedded within the mapping application. When the grid became populated with a data store, in this case:
                var data = {
                    identifier: "col_ID", //pk
                    label: "col_label", //display field
                    items: allItems
                //create data store and bind to grid
                store = new ItemFileReadStore({
                    data: data
                var grid = registry.byId("jGrid");
                grid.setStore(store);
...the array allItems created a circular reference in the API print widget JavaScript during jsonification of the map. I resolved it, not so elegantly as it were, by performing a deep clone of the data store's items array. Here's the resolution for me:
                //deep clone original items object
                var newArray = JSON.parse(JSON.stringify(allItems.slice()));
                var data = {
                    items: newArray
                //create data store and bind to grid.
                    data: data
Hope this helps!
