Hi All,
I have a JavaScript application (3.23) which I am trying to move from a ArcGIS for Server 10.4.1 environment with web adaptor to a ArcGIS Server 10.8.1 environment with F5 load balancer and no web adaptor. I published the Export Web Map geoprocessing tool and am able to run it successfully from the rest endpoint. I have tried to run it from my application without the use of a proxy and I receive an error of code 400, Invalid URL. When I try to run the print request through the proxy I get an error code of 500, unable to load.
Unfortunately, I have many problems!
1. I made a change to the proxy.config based on the most recent version in GitHub and now when I try to ping the proxy.ashx file, I get "<ProxyConfig xmlns="> was not expected." The proxy.config file which I downloaded from GitHub has xmlns=proxy.xsd in it. I have tried to remove this and am unable to get the change recognized (My web server is IIS). What is the best way to refresh the proxy?
2. I have tried so many different combinations of urls in my proxy.config that I am now officially dizzy! Can someone please describe for me what the different parts of this file are? I understand (I think) that the allowed referrers are the url that I am allowing access to my print service. What are the server urls? What happens when there are multiple server urls?
The attached txt file has code in it matching my proxy.config and default.aspx files.
I hope that someone out there can understand this and has a solution for me!
Janice.
