Hi!
I am not sure if you got any help with this or not (hopefully you solved it by now), but I got the same error when taking my first stumbling steps at creating a widget, so I had a look at your code (googled the error and found this question). I found out, that if I changed the contructor (in your TimeSlider.tsx) to this:
constructor(params?: any) {
super();
instead of yours:
constructor(start: Date, end: Date, current?: Date, params?: Partial<__esri.WidgetProperties>) {
super(params);
this.viewModel = new TimeSliderVM(start, end, current);
then the error didn´t happen. Then of course you need to change the call to creating a new TimeSlider (in main.ts) from:
const timeSlider = new TimeSlider(start, end, now);
To something like this:
const timeSlider = new TimeSlider({
container: "widgetDiv",
view: view
And now you should at least se a div on the right having the text 'Time Slider'. After that you still have lots of work to do before the TimeSlider actually works, but this is perhaps a start. And if someone else gets the same error, this might be a help.
By the way, I used JavaScript API 4.13 and hade the same error.
