Is it possible to create multipatch feature layers (with geometry information retured from a non-ArcGIS Server webservice) that I can symbolize using a unique value renderer using picture fill symbols like this:
If not picture fill symbols, can I do this:
I'd also like to be able to set a transparent color in the picture fill symbol so I can do something like this:
And lastly, can I create multipatch sphere slices and color them with a unique value renderer like this:
All of these were created with ArcObjects displayed in ArcScene
in arcgis pro you can export symbol 3d to json and see with js api .
addin in c# arcgis-pro-sdk-community-samples/Map-Authoring/ExportWeb3DObjectResource/ExportWeb3DObjectResource a...
I have taken a soe arcobjects that create a multipatch on the fly (manhole) and use viewer cityengine. You can do like it
getCameretta3D( alsi/Camerette3D ) (set for example oid = 100 )
here you can see specific Esri i3s: GitHub - Esri/i3s-spec: This repository hosts the specification for the ArcGIS Scene Service, includ...
see also http://proceedings.esri.com/library/userconf/devsummit16/papers/dev_int_01.pdf
