SwipeWidget and Sublayer
1425
03-05-2021 09:13 AM
JB19
Hello everyone,
I work with Arcgis JS Api 4.18
I would like to use two Sublayers from a MapImageLayer in a Swipe Widget.
But when I try to do that, I get this error :
[esri.core.Accessor] Accessor#set Assigning an instance of 'esri.layers.support.Sublayer' which is not a subclass of 'esri.layers.Layer'
I understand what is causing this error but I would like to know how to solve this.
I've tried to get the service URL from these two sublayers and to create two new MapImageLayers on the fly but I feel that's not the right way to do it.
Could you please tell me what would be the best way to handle this issue ?
Thanks.
angelforero
Hello JB19,
Could you solve your issue? Actually, I have the same doubt with the Swipe widget in react for @arcgis/core 4.23.7 However, If you found some trick to use sublayers in Swipe despite the limitation:
  • There is no current support for GroupLayer in the leadingLayers or trailingLayers.
please tell me.
Thanks in  advance
