Supports Calculate attribute
515
03-21-2019 07:52 AM
EvelynHernandez
Hello there
Is there a way to unclock the "supports calculate" attribute in a Featurelayer?
Thanks in advice.
RobertScheitlin__GISP
??? What do you mean. As the documentation states this is only an option for hosted services on AGOL currently.
<Boolean> supportsCalculate
When true, the layer supports the Calculate REST operation when updating features. Requires ArcGIS Online hosted feature service. (Added at v3.11)
Known values: true | false
Evelyn,
   There is no way that I am aware of. If the layer has editing enabled then this is enabled for hosted layers.
EvelynHernandez
What about the rest service? how to active that?
