Style sheet file not working in arc experience developer edition in another react component
779
03-23-2022 02:38 AM
MennaAyman
Hello
in ArcExperience Developer Edition
I am working on widget and i need to render children components inside it so i created new react component when i import style sheet file , it doesnt work , it works only on the widget component,
is there any solution?
SumitZarkarCT
@MennaAyman
It should work on both  custom components and the main widget.
Here is the sample in which I have created MyComponent and applid color to the tet from style
MennaAyman
Thanks alot but what about if i need to use css functions it will work in ts file or the css object will serialized it ??
SumitZarkarCT
@MennaAyman  - CSS functions work in ts file as well, I used calc css function many times.
Here is an example:
You can find more details about Styling your widget experience-builder/guide/widget-ui/#style-your-widget .
