Setting proxy to work with localhost
3074
10
11-26-2018 10:33 AM
MKF62
Occasional Contributor III
I'm trying to use my development environment to work on some things and currently the data on my map gets loaded through a proxy service. The proxy isn't set up to allow a localhost referrer so I would like to do so. I think this would be possible but I'm struggling to get it to work. I get a 404 error. Request URL comes out looking like this:
http://locahost:14906/appName/proxy/proxy.ashx?https://www.mydomain.org/myserver/rest/services/Habit...
Current config file:
<ProxyConfig allowedReferers="https://www.mydomain.org/*,http://localhost:14906/*"
             mustMatch="true"
             logFile="proxyLog.txt"
             logLevel="Warning">
    <serverUrls>
      <serverUrl url="https://www.mydomain.org/myserver/rest/services/HabitatManagement/HabitatManagement/GPServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true"/>
      <serverUrl url="https://www.mydomain.org/myserver/rest/services/HabitatMonitoring/HabitatData/MapServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
      <serverUrl url="https://www.mydomain.org/myserver/rest/services/HabitatMonitoring/HabitatClassification/GPServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
    </serverUrls>
</ProxyConfig>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Do I need to add localhost somehow as serverUrls? I'm not sure how that would look because accessing my rest services from localhost uses the same server URLs seen in the above code. You can't access them like "http://localhost:14906/myserver/rest/services/...."
MKF62
I figured it out. The proxy folder does sit in the application, however when I run it in the development environment it doesn't take the name of the application into account, so the proxyRule in my JS needed to be tweaked a little:
//Got rid of the appName before the /proxy in proxyUrl property
urlUtils.addProxyRule({
                urlPrefix: "https://www.mydomain.org",
                proxyUrl: "/proxy/proxy.ashx"
Works with this in proxy config file:
<!--For testing in development environment-->
<ProxyConfig allowedReferers="*"
             mustMatch="true"
             logLevel="Warning">
    <serverUrls>
      <serverUrl url="https://www.mydomain.com/myserver/rest/services/HabitatManagement/HabitatManagement/GPServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true"/>
      <serverUrl url="https://www.mydomain.com/myserver/rest/services/HabitatMonitoring/HabitatData/MapServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
      <serverUrl url="https://www.mydomain.com/myserver/rest/services/HabitatMonitoring/HabitatClassification/GPServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
      <serverUrl url="https://www.mydomain.com/myserver/rest/services/PrintHabitatMaps/PrintHabitatMap/GPServer"
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
    </serverUrls>
RobertScheitlin__GISP
Molly,
   The easiest way to make it work is to just change allowedReferers to "*"
MKF62
Bummer, I have tried that. I have also tried setting mustMatch to false to no avail.
             mustMatch="true"
             logLevel="Warning">
    <serverUrls>
                 username="xxx"
                 password="xxx"
                 matchAll="true"/>
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
                 username="xxx"
                 password="xxx"
                 matchAll="true" />
    </serverUrls>
</ProxyConfig>
Molly,
  So based on your url your localhost is using port 14906? and your proxy in inside your apps folder?
MKF62
Yes to port number. Proxy is located inside of the app folder. So http://localhost:14906/appName <-- proxy sits in this app.
You gave me an idea though. Do you think I need to edit the urlPrefix in the proxy rule? Currently it is set to the actual production environment.
                proxyUrl: "/appName/proxy/proxy.ashx"
Molly,
   No the urlPrefix is fine if you are only trying to proxy url that are going to https://www.mydomain.org
Have you tried: http://locahost:14906/appName/proxy/proxy.ashx?ping to see if the proxy is working?
MKF62
Ah, it is not. I get a "Server Error in '/' Application" - resource cannot be found error (404).
Testing the proxy with the actual domain name (while in the development environment) does respond correctly, so that's working.
Molly,
  Have you set the app folder up as an "application" in IIS?
MKF62
Yes, it is currently a working MVC application. The stuff I am testing will be a new addition to the application. The JS for the web map is nested inside this MVC application as is the proxy folder.
I am not sure what is going wrong then. Yoiu have to get the proxy ping working before you can continue though.
