Search widget+4.11
1328
04-13-2019 08:52 AM
anjelinaponkerat
Hi
I migrated from arcgis java script 4.9  to 4.11, after migration the "Search Widget" don't work!!
RobertScheitlin__GISP
Anjelina,
   In 4.11 the search widgets layer property takes a Layer class and not specifically a FeatureLayer class so you can not autocast as FeatureLayer as you use to in 4.9 when it was Only expecting a FeatureLayer. So your code would need to look like:
var searchWidget = new Search({
  view: view,
  allPlaceholder: "search...",
  sources: [{
    layer: new FeatureLayer({ //Notice the property is called layer Not featureLayer
      url: "localhost:6080/arcgis/rest/services/city/FeatureServer/0",
      popupTemplate: { // autocasts as new PopupTemplate()
        title: "name: {name2} </br>{name_new}",
        overwriteActions: true
    searchFields: ["name2"],
    displayField: "name2",
    exactMatch: false,
    outFields: ["name2", "name2"],
    placeholder: "name2",
    maxResults:10,
    maxSuggestions:50,
    autoNavigate: true,
    //enableSuggestions: true //This is not a property of a layerSearchSource
Egge-Jan_Pollé
MVP Regular Contributor
Hi anjelina ponkerat‌,
Your issue is most probably caused by differences between the two versions of the ArcGIS API for JavaScript, version 4.9 and 4.11. So, just migrating to the new version apparently is not enough - because this breaks your application.
The best way forward is to keep the 4.9 app in production until you have rewritten and fully tested the new 4.11 app.
Here you can find a 4.11 sample for the Search Widget | ArcGIS API for JavaScript 4.11
HTH,
Egge-Jan
anjelinaponkerat
But what's the reason of this problem? I searched release note of 4.11 and didn't find any changes in new version(4.11)
Anjelina,
   There have been several changes to the search widget and new classes added that the widget now uses. So it is hard to say without seeing your code what the issue is. If you go to the release notes https://developers.arcgis.com/javascript/latest/guide/release-notes/ and search for the word "search" you will find that there are new classes and new methods added in 4.11 and other change in 4.10. https://developers.arcgis.com/javascript/latest/guide/4.10/index.html
anjelinaponkerat
view: view,
sources: [{
featureLayer: {
exactMatch: false,
maxResults:10,
maxSuggestions:50,
autoNavigate: true,
featureLayer: {
url: "localhost:6080/arcgis/rest/services/city/FeatureServer/1",
title: "name: {cc} </br>{c1cc}",
searchFields: ["cc"],
displayField: "cc",
exactMatch: false,
outFields: ["cc", "c1cc"],
placeholder: "search1",
exactMatch: true,
zoomScale:13000,
maxResults:10,
maxSuggestions:50,
autoNavigate: true,
view.ui.add(searchWidget, {
position: "top-left",
index: 2
Anjelina,
  view: view,
  sources: [{
    exactMatch: false,
    maxResults:10,
    maxSuggestions:50,
    autoNavigate: true,
