Reverse geocode map on click 4.17
1914
12-06-2020 11:40 AM
laitha0
Hello, I am using the latest API version and it seems like there are some changes so the previous questions and posts are not helping me solve this problem.
I am trying to lookup an address by clicking on the map but I keep getting:
locator.locationToAddress is not a function
Below is my code, I tried to console.log(locator) and I do not see any methods, I'm not sure if I am creating the Locator object properly
this.view.on("click", event =>{
    this.view.graphics.removeAll();
    var point = {
        type: "point", // autocasts as new Point()
        longitude: event.mapPoint.longitude,
        latitude: event.mapPoint.latitude,
    var markerSymbol = {
        type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
        color: [226, 119, 40]
    var pointGraphic = new Graphic({
        geometry: point,
        symbol: markerSymbol
    this.view.graphics.add(pointGraphic);
    console.log("errr");
    var locator = new Locator({
        url: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
    console.log(locator);
    locator.locationToAddress({location: event.mapPoint}).then(function(response){
        console.log(response);
    this.clickedOnMap(event);
 In the same file above this I am using esri-loader with Reactjs  and I load the modules using
loadModules(["esri/Map", "esri/views/MapView", "esri/widgets/Search", "esri/Graphic", "esri/geometry/Point", "esri/tasks/Locator", "esri/geometry/SpatialReference", "esri/geometry/support/webMercatorUtils"], { css: true })
            .then(([ArcGISMap, MapView, Search, Graphic, Locator, SpatialReference, webMercatorUtils, Point]) => {
SNIP
I hope someone would be able to help me with this.
Ethan
by Esri Contributor
Hi Laitha,
When using loadModules, the order of the imports does need to match I think. Try moving "Point" between "Graphic" and "Locator" after the .then like this:
             { css: true }).then(([ArcGISMap, MapView, Search,
                                   Graphic, Point, Locator,
                                   SpatialReference, webMercatorUtils]) => {}
Hope that helps! You may also find these resources helpful:
https://developers.arcgis.com/labs/browse/?product=javascript&topic=geocoding
Ethan
by Esri Contributor
Hi Laitha,
laitha0
very interesting the order did matter !
I just moved Locator before Point and created the Locator before adding the graphic to the map and now it worked !!
laitha0
Thanks for the help @Ethan
