Return all the attributes(fields) in a feature layer for a PopupTemplate - ArcGis Javascript
940
01-03-2022 02:23 AM
MuhammadArsalan27
Is there a way to return all the attributes(fields) in a feature layer for a PopupTemplate, without declaring all of them in the fieldInfos object in Angular?
.ts
const template = {
        title: "{NAME} in {COUNTY}",
        content: ,
        fieldInfos : fieldInfos
     const layer = new FeatureLayer({
      url: this.featureLayerUrl,
      visible: true,
      popupTemplate : template
      var fieldInfos = layer.map(layer.fields, function(field){
         return {
                "fieldName": field.name,
                "label": field.alias,
                "visible": true
    webmap.add(layer);
.html
    <!-- Map Div -->
I’m using arcgis-js-api version 4.2.1.
But when I use this example it is working. (But I want to set these fields dynamically.)
const fields = [{
  alias: "Name",
  type: "string"
  alias: "County",
  type: "string"
const config = {
  fields: fields,
  title: "County land"
ReneRubalcava
Honored Contributor
You can use the createPopupTemplate method on the layer.
view.when(() => {
  const popupTemplate = featureLayer.createPopupTemplate();
  featureLayer.popupTemplate = popupTemplate;
UndralBatsukh
You also need to set MapView.popup.defaultPopupTemplateEnabled to true on top of what @ReneRubalcava  pointed out.
