Hello everyone,
I am getting the following error message
"Unable to load /proxy/?http://localhost/FindNextVALUENumber/api/value status: 404"
when running this sample:
https://developers.arcgis.com/javascript/3/jssamples/data_requestJson.html
When I pass these URLs, the first one works fine but the second one fails
url = "http://localhost:59297/api/value"; <ç========WORKS FINE – it is the Visual Studio 2012 proejct
Or
url = "http://localhost/FindNextVALUENumber/api/value"; <ç==== FAILS – runs from IIS
The second URL is the IIS Application pointing to the same folder.
I am using the proxy server from this sample: https://github.com/Esri/resource-proxy
I tested both url and they work fine with the proxy:
http://localhost/proxy/proxy.ashx?http://localhost:59297/api/value
http://localhost/proxy/proxy.ashx? http://localhost/FindNextVALUENumber/api/value
Here is the proxy.config file
<ProxyConfig allowedReferers="*" mustMatch="true">
<serverUrls>
<serverUrl url="http://localhost:61004"
matchAll="true"/>
<serverUrl url="http://localhost:59297"
matchAll="true"/>
<serverUrl url="http://localhost"
matchAll="true"/>
</serverUrls>
</ProxyConfig>
My code:
esriConfig.defaults.io.proxyUrl = "/proxy/";
var url = "http://localhost:59297/api/value";
dom.byId("url").value = url;
dom.byId("content").value = "";
//handle the Go button's click event
on(dom.byId("submitRequest"), "click", getContent);
var serviceDescriptionStr = "";
function getContent() {
var result = "";
var contentDiv = dom.byId("content");
contentDiv.value = "";
domClass.remove(contentDiv, "failure");
dom.byId("status").innerHTML = "Downloading...";
var requestHandle = esriRequest({
"url": url,
handleAs: "json"
requestHandle.then(
function (response) {
console.log("Data: ", response);
dojoJson.toJsonIndentStr = " ";
console.log("Success: ", response);
function (error) {
console.log("Error: ", error.message);
alert(error.message);
