Query task and function not drawing my polygons?
1380
04-26-2019 11:22 AM
JeremySingh1
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>Intro to FeatureLayer - 4.11</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.11/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.11/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/tasks/support/Query",
"esri/tasks/QueryTask",
"esri/Graphic"
], function(Map, MapView, FeatureLayer, Query,QueryTask,Graphic) {
var map = new Map({
basemap: "topo"
var view = new MapView({
container: "viewDiv",
map: map,
center: [-73.98,40.74],
zoom: 13
* Add feature layer
// var featureLayer = new FeatureLayer({
// url:
// "https://services1.arcgis.com/JPUKRee8mEBfJ0K4/arcgis/rest/services/Subway/FeatureServer"
//map.add(featureLayer);
var query = new Query();
query.where = "LINE ='BMT'";
query.outFields = [ "*" ];
query.returnGeometry = true;
var queryTask = new QueryTask({
url:"https://services1.arcgis.com/JPUKRee8mEBfJ0K4/arcgis/rest/services/Subway/FeatureServer"
queryTask.execute(query)
.then(function(result){
//console.log(result.features.length)
//*** ADD ***//
result.features.forEach(function(item){
var g = new Graphic({
geometry: item.geometry,
attributes: item.attributes,
symbol: {
type: "simple-marker",
color: "black",
width: 1.2,
style: "short-dot"
view.graphics.add(g);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Tags (3)
RobertScheitlin__GISP
Jeremy,
   You have several issue in your code on closer inspection.
1. The querytask url has to point to a specific layer in the service.
2. The where clause has to use fields and values that are actually in the service.
Your url has one layer so the url would be:
  url: "https://services1.arcgis.com/JPUKRee8mEBfJ0K4/arcgis/rest/services/Subway/FeatureServer/2"
But that layer does Not have a Line field in it so your query is invalid.
This is what it should be:
      query.where = "SubwayCounts_2016_LINE ='BMT'";
      query.outFields = ["*"];
      query.outSpatialReference = view.spatialReference;
        .then(function(result) {
          //*** ADD ***//
          result.features.forEach(function(item) {
              symbol: {
                color: "black",
                width: 1.2,
                style: "circle"
Jeremy,
   You just need to set the outSpatialReference of the query class to be the same as the view.spatialReference.
JeremySingh1
Thanks Robert, I still seem to have the issue. Im a bit new to this.
My changes are below:
query.outSpatialReference = view.spatialReference; *******Added this line.
Jeremy,
          //*** ADD ***//
              symbol: {
                color: "black",
                width: 1.2,
                style: "circle"
JeremySingh1
Thank you! this works!
