PROXY and CORS (Control-Allow-Origin)
13667
8
04-28-2016 05:30 AM
RobertoOliveira
I'm having problems to set the proxy for my application!
My current setup:
- ArcGIS Server 10.4 on 'server.virtual.private' or '192.168.210.100'
- Proxy .NET running with IIS 8.5 on 'server.virtual.private' (same machine than ArcGIS Server 10.4)
- Application with Javascript API 3.16 on 'host-vm' or '192.168.210.1' (with browsersync.io)
Installed the proxy from GitHub
Put the .NET version on a inetpub\wwwroot subfolder, created a app, etc...
Then, I tested the proxy (according with the README.md):
"Test that the proxy is installed and available":
http://server.virtual.private/DotNet/proxy.ashx?ping!
Got a valid response:
{ "Proxy Version": "1.1.0", "Configuration File": "OK", "Log File": "Not Exist/Readable"}
"Test that the proxy is able to forward requests directly in the browser using":
http://server.virtual.private/esri_proxy/proxy.ashx?http://server.virtual.private/arcgis/rest/servic...
   "currentVersion":10.4,
   "serviceDescription":"TEST_SERVICE",
   "hasVersionedData":false,
   "supportsDisconnectedEditing":false,
   "syncEnabled":false,
   "supportedQueryFormats":"JSON, AMF",
   "maxRecordCount":1000,
   "capabilities":"Create,Delete,Query,Update,Uploads,Editing",
   "description":"",
   "copyrightText":"",
   "spatialReference":{
      "wkid":102100,
      "latestWkid":3857
   "initialExtent":{
      "xmin":-5373925.95008382,
      "ymin":-1779327.897638279,
      "xmax":-5367538.895643042,
      "ymax":-1776174.0579972658,
         "wkid":102100,
         "latestWkid":3857
   "fullExtent":{
      "xmin":-5371483.1645,
      "ymin":-1779695.3658000007,
      "xmax":-5368931.5394,
      "ymax":-1776737.2322000004,
         "wkid":102100,
         "latestWkid":3857
   "allowGeometryUpdates":true,
   "supportsApplyEditsWithGlobalIds":false,
   "units":"esriMeters",
   "documentInfo":{
      "Title":"",
      "Author":"",
      "Comments":"",
      "Subject":"",
      "Category":"",
      "Keywords":"TEST_SERVICE"
   "layers":[
         "id":0,
         "name":"TEST_SERVICE"
   "tables":[
   "enableZDefaults":false
So, the proxy appear to be OK!
Then, I edited the proxy.config file, with this content (this is for test development):
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*" mustMatch="false">
  <serverUrls>
      <serverUrl url="http://server.virtual.private" matchAll="true" username="siteadmin" password="secret" />
  </serverUrls>
</ProxyConfig>
Then, according with README.md​, and document on Using the proxy | Guide | ArcGIS API for JavaScript I must put the URL of the proxy on my javascript application.
I put the following lines on top of main file of application:
esriConfig.defaults.io.proxyUrl = 'http://server.virtual.private/DotNet/proxy.ashx';
esriConfig.defaults.io.alwaysUseProxy = false;
Tested my application and got a 500 response when asked for a Feature Layer.
"XMLHttpRequest cannot load http://server.virtual.private/DotNetProxy/proxy.ashx?http://server.virtual.private/arcgis/rest/servi.... Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested source. Origin 'http://192.168.210.1:8080' is therefore not allowed access.".
So, I got a CORS! but according with the documentation on Using the proxy | Guide | ArcGIS API for JavaScript​:
"ArcGIS Server 10.1 supports CORS out of the box."
OK, I have some problems now!!
In same documentation:
"For earlier versions, an administrator can add CORS support. Visit enable-cors.org for detailed instructions"
Let's try anyway!
Modified the web.config file on proxy application on IIS (from lines 07 to 15).
<?xml version="1.0"?>
<configuration>
  <system.web>
    <compilation debug="false" targetFramework="4.0"/>
  </system.web>
  <system.webServer>
    <httpProtocol>
      <customHeaders>
        <add name="Access-Control-Allow-Origin" value="*" />
        <add name="Access-Control-Allow-Headers" value="*" />
        <add name="Access-Control-Allow-Methods" value="*" />
      </customHeaders>
    </httpProtocol>
  </system.webServer>
  <system.diagnostics>
    <switches>
      <add name="TraceLevelSwitch" value="Info" />
    </switches>
    <trace autoflush="true" indentsize="4">
      <listeners>
        <add name="agsProxyLogListener" type="System.Diagnostics.TextWriterTraceListener"
             initializeData="C:\Temp\Shared\proxy_logs\auth_proxy.log" />
        <remove name="Default" />
      </listeners>
    </trace>
  </system.diagnostics>
</configuration>
Now, I get a new error!
"XMLHttpRequest  cannot load http://server.virtual.private/DotNetProxy/proxy.ashx?http://server.virtual.private/arcgis/rest/servi.... Request header field X-Requested-With is not allowed by Access-Control-Allow-Headers in preflight response.".
So, what's the correct way to configure the proxy? Because I do everything that was on documents, and got errors.
RobertoOliveira
This seens be a bit stranger, but I have changed the web.config to original version (the same on github) and included the following line in my code:
esriConfig.defaults.io.corsEnabledServers.push('server.virtual.private');
Everything worked without the changes on web.config!
Then, I removed the line corsEnabledServer, and code was still working!
The problem was resolved, but I really do not know how!
Edit: the "error" occur again! instead of modify all the web.config file again, the esriConfig.defaults.io.corsEnabledServer.push function resolved the problem this time!
This function was not on main documentation about CORS. I found this function looking at the API Reference, and on some sample codes.
RobertoOliveira
I "resolved" the problem, with the following content on Web.config file of DotNet Proxy (lines 07 to 15 from previous version):
<system.webServer>
  <httpProtocol>
    <customHeaders>
      <add name="Access-Control-Allow-Headers" value="Authorization, Origin, X-Requested-With, Content-Type, Accept, User-Agent" />
      <add name="Access-Control-Allow-Methods" value="GET, POST, PUT, DELETE, OPTIONS" />
    </customHeaders>
  </httpProtocol>
  </system.webServer>
But this don't seems to be the correct method! In any part of documentations of DotNet Proxy, Javascript API or Server REST API have any information that I must modify the Web.config file for this version.
Any ideas?
DanMcCoy
arunepuri1
The solutions worked for me with esriRequest
Done the below changes in dotnet proxy => web.config
<system.webServer>
<httpProtocol>
<customHeaders>
<add name="Access-Control-Allow-Origin" value="https://localhost:44332" />
<add name="Access-Control-Allow-Credentials" value="true" />
</customHeaders>
</httpProtocol>
</system.webServer>
Added the below code in widget.js
esri.config.defaults.io.proxyUrl = "https://hostservername.com/proxy/proxy.ashx";
esri.config.defaults.io.corsEnabledServers.push("servicehostname.com");
var requestHandle = esriRequest({
url: URL,
handleAs: "json",
headers: { "Accept": "application/json" },
timeout: 10000
}, { useProxy: true, usePost: false, disableIdentityLookup: true });
requestHandle.then(lang.hitch(this, function (results, io) {
console.log(results);
RobertoOliveira
BrianO_keefe
Where did this line of code GO...? In the web.config? In the Web App Builder? I'm lost...
RobertScheitlin__GISP
Brain,
   You are looking in the JS API space so the answer provided was a line of code to be added to the JS API custom apps code.
BrianO_keefe
Ahhhh... I'm having a similar issue and hitting dead ends... thanks man.
Brain,
   For WAB look here:
Work with web-tier authentication—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Develop...
In the main config.json there is a "authorizedCrossOriginDomains": [],
