Print Widget graphic on legend
3086
11-04-2014 02:54 AM
francescodi_vito
Hello everyone,
i'm using a print widget in a javascript webapp. The layout that i use are custom e works very well.
I integrated in the webapp a widget for geocoding and other selection widget that return a graphic point.
If i run the printing tool when the graphic point result is on the map in my PDF i have in legendo the symbol graphic with a label "override". It's possibile to change this name of graphic in legend?
MichaelTownshend
Were you ever able to find a solution to this problem?  I am running into the same thing now and the client would really like that changed.
