Print Token-Secured Service JS 3.10
2669
08-27-2014 06:35 PM
AlexeiB
Hi There,
I'm trying to print a secured web service using the new JS 3.10.
In 3.9 I had a heck of a time with it and was able to get around the issue by appending a short-lived token to my service URLs which allowed the map to print. This solution however does not seem to work in 3.10.
Does anyone have any idea how to print a secured web service using JS 3.10?
Thank you,
Alex
AlexeiB
Well I solved it.
What I ended up doing was dynamically creating a new map that is the exact same map that the user sees but the only thing that changes is the fact I set the URL of my services to make sure they can be accessed via the print function. This was a big headache because in 3.9 I could simply add a token my map services and use that to print. But 3.10 did not pick up the new token URL that I set in my map and therefore had to make a brand new map on the fly.
Anyways, it works.
AlexeiB
Well I solved it.
Anyways, it works.
