Hi All,
I'm attempting to create a FeatureLayer from an array of graphics and have been able to get features to display on a map, but I'm not able to click on them to use the PopupTemplate. In earlier version of the js api 3.x I was able to get this to work, but I haven't had any success with version 4.2. I've attached all of my code and kept it as simple as possible. Does anybody know why the PopupTemplate isn't displaying?
Code Follows:
<!DOCTYPE html>
<html lang="en" xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<meta name="date" content="January 12, 2017" />
<title>Station Location Map</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css" />
<style>
html, body {
height: 100%;
#viewDiv {
padding: 0%;
margin: 0%;
height: 100%;
width: 100%;
</style>
<script src="https://js.arcgis.com/4.2/"></script>
<script src="http://code.jquery.com/jquery-3.1.1.min.js" integrity="sha256-hVVnYaiADRTO2PzUGmuLJr8BLUSjGIZsDYGmIJLv2b8=" crossorigin="anonymous"></script>
<script>
function station(name, location, latitude, longitude, url) {
this.name = name;
this.location = location;
this.latitude = latitude;
this.longitude = longitude;
this.url = url
var stations = [];
stations.push(new station("Station 1", "Canisteo River", 42.1, -77.2, "http://www.google.com"));
stations.push(new station("Station 2", "Juniata River", 40.5, -78.0, "http://www.google.com"));
stations.push(new station("Station 3", "Chiques Creek", 40.2, -76.3, "http://www.google.com"));
console.log('Array is populated...')
require([
"esri/Basemap",
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/layers/MapImageLayer",
"esri/geometry/Point",
"esri/Graphic",
"esri/PopupTemplate",
"esri/renderers/SimpleRenderer",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/widgets/BasemapToggle",
"esri/widgets/Home",
"dojo/domReady!"],
function (
Basemap,
Map,
MapView,
FeatureLayer,
MapImageLayer,
Point,
Graphic,
PopupTemplate,
SimpleRenderer,
SimpleMarkerSymbol,
SimpleLineSymbol,
SimpleFillSymbol,
BasemapToggle,
Home
var stationFeatureLayer;
var fields = [
alias: "ObjectID",
type: "oid"
alias: "name",
type: "string"
alias: "location",
type: "string"
alias: "url",
type: "string"
var popupTemplate = new PopupTemplate({
title: "{name}",
content: [{
type: "fields",
fieldInfos: [{
fieldName: "location",
label: "Location",
visible: true
fieldName: "url",
label: "More info",
visible: true
var map = new Map({
basemap: "satellite"
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 7,
center: [-77, 41.25]
// symbolization //
var simpleLineSymbol = new SimpleLineSymbol({
color: "black",
width: "1px",
style: "solid"
// Circle Marker (DEFAULT)
var simpleMarkerSymbolDefault = new SimpleMarkerSymbol({
style: "circle",
color: "red",
outline: simpleLineSymbol
var stationsRenderer = new SimpleRenderer({
symbol: simpleMarkerSymbolDefault,
label: "Monitoring Site"
var basemapToggle = new BasemapToggle({
view: view,
nextBasemap: "streets"
basemapToggle.startup();
view.ui.add(basemapToggle, "top-right");
var home = new Home({
view: view
view.ui.add(home, "top-left");
var graphics = [];
view.then(function () {
console.log("view.then");
var i = 0;
for (s in stations) {
console.log(stations.latitude);
var pt = new Point(stations.longitude, stations.latitude);
var attr = { "ObjectID": i, "name": stations.name, "location": stations.location, "url": stations.url }
console.log(attr);
var graphic = new Graphic({
attributes: attr,
geometry: pt,
popupTemplate: popupTemplate
graphics.push(graphic);
i = i + 1;
featureLayer = new FeatureLayer({
source: graphics,
fields: fields,
objectIdField: "ObjectID",
renderer: stationsRenderer,
geometryType: "point", // Must be set when creating a layer from Graphics
console.log(featureLayer);
map.add(featureLayer);
</script>
</head>
<body>
<div id="viewDiv">
</div>
</body>
</html>
Hi David,
Using the graphics sample you supplied, I was able to get Popup Templates to work with an array of graphics. I'm not really sure what was causing the original problem with going the Feature Layer route, but I may revisit that another time. Originally, I was trying to manually create a Feature Layer because I thought it would give me better capabilities with selections and rendering. In some troubleshooting while I was coding I noticed that I needed to click at a very precise location in order to to trigger the popup, but I wasn't able to determine the cause, so I just did a complete re-write and the working code is below. My leading thoughts on what was going wrong with my original attempt would be the way I was populating the source with a function; creating a feature layer in the "view.then"; or possibly the way I was constructing my Popup Template. Thanks again for your help!
Final Solution - Different Approach that Uses Graphics Instead of Feature Layer Follows:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Test Map 4.2</title>
<!--ESRI JavaScript API-->
<link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/Graphic",
"esri/geometry/Polyline",
"esri/geometry/Polygon",
"esri/symbols/PictureMarkerSymbol",
"dojo/domReady!"
], function (
Map,
MapView,
Graphic,
Point,
Polyline,
Polygon,
PopupTemplate,
PictureMarkerSymbol,
SimpleMarkerSymbol,
SimpleLineSymbol,
SimpleFillSymbol,
BasemapToggle,
Home
// populate the array
this.name = name;
this.url = url
var stations = [];
stations.push(new station("station 1", "Canisteo River", 42.1, -77.2, "http://www.esri.com/"));
stations.push(new station("station 2", "Frankstown Branch Juniata River", 40.5, -78.0, "http://www.esri.com/"));
stations.push(new station("station 3", "Chiques Creek", 40.2, -76.3, "http://www.esri.com/"));
var map = new Map({
basemap: "hybrid"
center: [-77, 41.25],
map: map,
zoom: 8
view: view, // The view that provides access to the map's "streets" basemap
nextBasemap: "streets" // Allows for toggling to the "hybrid" basemap
// start the basemap toggle widget and add it to the view
view: view
// symbolization //
color: "black",
width: "1px",
style: "solid"
var simpleMarkerSymbol = new SimpleMarkerSymbol({
style: "circle",
color: "red",
var pt = new PopupTemplate({ // autocasts as new PopupTemplate()
title: "Station: {Station}",
content: [{
type: "fields",
fieldInfos: [{
fieldName: "Location"
fieldName: "Url"
// loop
// First create a point geometry (this is the location of the Titanic)
var point = new Point({
longitude: stations[s].longitude,
latitude: stations[s].latitude
// Create an object for storing attributes related to the line
var pointAtt = {
Station: stations[s].name,
Url: stations[s].url
// Create a graphic and add the geometry and symbol to it
var pointGraphic = new Graphic({
geometry: point,
symbol: simpleMarkerSymbol,
attributes: pointAtt,
popupTemplate: pt
// Add the graphics to the view's graphics layer
view.graphics.add(pointGraphic);
</script>
</head>
<body>
<div id="viewDiv">
</div>
</body>
</html>
Have you looked at this:
It's still not working. I can get PopupTemplates to work for map services but have not been able to get them to work when I'm building a FeatureLayer from an array of graphics.
Hi Chuck - are you able to sucessfully render the feature layer from the Graphic array and are the attribute values from the graphic showing as values in the fields array of your feature layer? My guess is that the popupTemplate for the feature layer isn't getting values or the popup doesn't have a location set - it doesn't know where to position itself in the view. I know that you don't need to set the popupTemplate on the graphic, just on the feature layer.
Also, you may want to move the station funciton and stations.push under your require
I'd check this sample out if you haven't already
Create a FeatureLayer with client side graphics | ArcGIS API for JavaScript 4.2
Hi David,
Thanks for your suggestions and I actually used the sample when I wrote this code, but it's different as my requirements don't have the data coming from a service. I've tried a few changes, but haven't been able to get the PopupTemplates to display. Using the console I've confirmed that there are populated features in the FeatureLayer.Source.Items array. I've also tried populating the graphics in separate function. It seems odd the the points draw in the correct location and have data (at least at the console level), but the PopupTemplate won't work.
My modified code is below:
<!DOCTYPE html>
<head>
<style>
html, body {
height: 100%;
#viewDiv {
padding: 0%;
margin: 0%;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Basemap",
"esri/Map",
"esri/geometry/SpatialReference",
"esri/Graphic",
"dojo/domReady!"],
function (
Basemap,
Map,
MapView,
FeatureLayer,
MapImageLayer,
Point,
SpatialReference,
Graphic,
PopupTemplate,
SimpleRenderer,
SimpleMarkerSymbol,
SimpleLineSymbol,
SimpleFillSymbol,
BasemapToggle,
Home
this.name = name;
this.url = url
var stations = [];
var fields = [
alias: "ObjectID",
type: "oid"
alias: "name",
type: "string"
alias: "location",
type: "string"
alias: "url",
type: "string"
title: "{name}",
content: [{
type: "fields",
fieldInfos: [{
label: "Location",
visible: true
fieldName: "url",
label: "More info",
visible: true
var map = new Map({
map: map,
zoom: 7,
// symbolization //
color: "black",
width: "1px",
style: "solid"
style: "circle",
color: "red",
view: view
layerId: 1,
outfields: "*",
source: createGraphics(),
fields: fields,
spatialReference: new SpatialReference(4326),
console.log('log of feature layer....')
function createGraphics()
var graphics = [];
var i = 0;
console.log(attr);
attributes: attr,
geometry: pt
i = i + 1;
return graphics;
</script>
</head>
<body>
<div id="viewDiv">
</div>
</body>
</html>
Ok so when you say the popup template doesn't work - does the popup display at all? Or does the popup display but with no attributes? Also not to be a pain but if you could use the javascript syntax highlighter for your code that would help - it's hard to read otherwise
I don't see the pop-up at all. When I console.log out values of variables it looks like all of the information is there with the attributes and I see points display on the map so it's really puzzling. I apologize for not using the syntax highlighter. I just now have found it. Thanks!
<!DOCTYPE html>
<head>
<style>
html, body {
height: 100%;
#viewDiv {
padding: 0%;
margin: 0%;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Basemap",
"esri/Map",
"esri/Graphic",
"dojo/domReady!"],
function (
Basemap,
Map,
MapView,
FeatureLayer,
MapImageLayer,
Point,
SpatialReference,
Graphic,
PopupTemplate,
SimpleRenderer,
SimpleMarkerSymbol,
SimpleLineSymbol,
SimpleFillSymbol,
BasemapToggle,
Home
this.name = name;
this.url = url
var stations = [];
var fields = [
alias: "ObjectID",
type: "oid"
alias: "name",
type: "string"
alias: "location",
type: "string"
alias: "url",
type: "string"
title: "{name}",
content: [{
type: "fields",
fieldInfos: [{
label: "Location",
visible: true
fieldName: "url",
label: "More info",
visible: true
var map = new Map({
map: map,
zoom: 7,
// symbolization //
color: "black",
width: "1px",
style: "solid"
style: "circle",
color: "red",
view: view
layerId: 1,
outfields: "*",
fields: fields,
var graphics = [];
var i = 0;
console.log(stations[s].latitude);
var pt = new Point(stations[s].longitude, stations[s].latitude);
var attr = { "ObjectID": i, "name": stations[s].name, "location": stations[s].location, "url": stations[s].url }
console.log(attr);
attributes: attr,
geometry: pt
// create a featureLayer from the graphics: https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html
i = i + 1;
return graphics;
</script>
</head>
<body>
<div id="viewDiv">
</div>
</body>
</html>
Right so you are close. The popup doesn't know where to position itself in the view. Your popup needs to have it's location set at your pt var. Here's how we return the popup from the search:
app.search.on("search-complete", function(evt){
console.log(app.mapView.popup);
if (app.activeView.popup.dockEnabled) {
app.mapView.popup.visible = true;
} else {
//set the popup location
app.mapView.popup.location = evt.results[0].results[0].feature.geometry.centroid;
app.mapView.popup.visible = true;}
in your case I think you just need to set your popup.location = pt;
Thanks for your help, but I'm still not able to figure out why it's not working. I'm not sure what the "app" is referring to in the code you supplied, maybe a widget has that method? I'm running a hit test and no graphics are being found so that's a clue for me. That was the closest way I could think of to get to something that gets to the same concept as your code. I'm convinced that I've either found a bug in 4.2 or that this is some type of sequencing problem where the the feature class is added to the map before other parts of the application are ready. It has something to do with my creating the feature layer in code and not calling a service. Doing a hit test on feature I can see on the map, but not getting any results from the hit test is a clue, but I'm not sure what to do with it. I'm sure that if I changed these points to a map service it would all work fine, but I don't really want to make an entire map service just for a handful of points. Thanks again for you help.
Hi Chuck, if you go here:
jsapi 4.0 popup: set highlight graphic on feature layer click?
you can see how we are using hitTest and then setting the graphic's geometry to the click response, in our case polygons. 'app' is just a var from the Calcite Maps and Bootstrap | ArcGIS API for JavaScript 4.2
calcite maps project that we started with instead of trying to port all of our 3.x css over. Yes we are rendering our feaure layers and adding to the map usint addMany, but what you are doing is essentially the same thing. At this point though I have to ask why are you trying to create a feature layer from these graphics? You don't need a feauture layer if all you want to do is show a popup since you've already defined the graphics' attributes.
