Popup.open() function used to highlight feature have an unstable error @ ArcGIS for JavaScript 4.20
1433
08-23-2021 09:18 AM
ForyondChao
My Server is ArcGIS Server 10.2,I published the mapping service using ArcMap 10.2 , and the layers data from database (SQL Server 2019) directly.  When I don't register the database, publishing maps automatically copies the data from the database to the server ,  a new unique field called OBJECTID is automatically added to the layer properties table ,  Popup is right now.
but, when I register the database to ArcGIS Server,  I  call the  popup.open()  function to show a feature's property,  some unfixed errors have occurred.   I noticed that the new unique field added by ArcGIS changed from OBJECTID to ESRI_OID,  I modified the codes, but, error still.  The error appeared is that when I popup a feature, the highlight geometry is part of the target feature or sometime is other feature. something like this:
but now the geometry obtained from server is correct, there are 6 points for the geometry.
Here is my code.
Could you please tell me how to fix this bug  or  possible reasons? Looking forward to your reply, Thanks!
ForyondChao
I used a simple method to get around this problem
1. Turn popUp's built-in highlighting off.
const view = new MapView({
 popup:{highlightEnabled:false}
2. Use the default graphic in the View to add color for geometry every time it is selected.
sym= new {
type:"simple-fill",
color:[0,255,255,0.5],
style:"solid",
outline:{color:[255,255,0], width:1, style:"solid"}
view.graphics.add(new Graphic({geometry:geometry, symbol:sym}));
Now I can achieve my goal, thanks to the forum!
ForyondChao
Hi  GarryGoldberg!
How do you to solve the problem ?
ForyondChao
sym= new {
type:"simple-fill",
style:"solid",
kukiyang
this is awesome, try it out! https://word-unscrambler.io
