Polygons not rendering after changing visibility property.
1151
10-06-2021 04:13 PM
Jimmy
Hello.  I am using the ArcGIS Javascript API.  Unfortunately I cannot share relevant code.
I am having an issue with re-rendering certain polygons through their visibility property on a featurelayer after running the Featurelayer.applyEdits() function.
This issue only occurs with polygons that have rings with the same x and y coordinates.
Drawing the polygon for the first time works fine.
Any insight on why it behaves this way?
Here is the error:
[esri.views.3d.layers.graphics.Graphics3DCore] Graphic in layer [layer.id] has no geometry and will not render
This polygon does not re-render:
  let myEsriPolygon = new EsriPolygon({
    rings: [
      [[0,1,150], [1,1,150], [1,0,150], [0,0,150], [0,1,150]],
      [[0,1,15000], [1,1,15000], [1,0,15000], [0,0,15000], [0,1,15000]],
Example line of code:
FeatureLayerView.FeatureLayer.applyEdits({ updateFeatures: GraphicArray });
