I am using this code to draw a circle:
$('#circle').click(function () {
clearPreviousSearch();
map.disableMapNavigation();
$('#run').fadeOut();
buttonclickvalue = 'circle';
drawToolbar.activate(esri.toolbars.Draw.CIRCLE);
I've been told I need this code to constrain the radius:
<SPAN class="kwd">var</SPAN><SPAN class="pln"> circle </SPAN><SPAN class="pun">=</SPAN><SPAN class="pln"> </SPAN><SPAN class="kwd">new</SPAN><SPAN class="pln"> </SPAN><SPAN class="typ">Circle</SPAN><SPAN class="pun">({</SPAN><SPAN class="pln"><BR /> center</SPAN><SPAN class="pun">:</SPAN><SPAN class="pln"> e</SPAN><SPAN class="pun">.</SPAN><SPAN class="pln">mapPoint</SPAN><SPAN class="pun">,</SPAN><SPAN class="pln"><BR /> geodesic</SPAN><SPAN class="pun">:</SPAN><SPAN class="pln"> domAttr</SPAN><SPAN class="pun">.</SPAN><SPAN class="kwd">get</SPAN><SPAN class="pun">(</SPAN><SPAN class="pln">geodesic</SPAN><SPAN class="pun">,</SPAN><SPAN class="pln"> </SPAN><SPAN class="str">"checked"</SPAN><SPAN class="pun">),</SPAN><SPAN class="pln"><BR /> radius</SPAN><SPAN class="pun">:</SPAN><SPAN class="pln"> </SPAN><SPAN class="lit">100</SPAN><SPAN class="pun">,</SPAN><SPAN class="pln"> <BR /> radiusUnit</SPAN><SPAN class="pun">:</SPAN><SPAN class="pln">units</SPAN><SPAN class="pun">.</SPAN><SPAN class="pln">MILES<BR /></SPAN><SPAN class="pun">});</SPAN>
But where on earth should it go - it's driving me nuts!!
