passing map object between forms
4349
12
11-03-2016 10:15 AM
BrianFoley1
Since I am having trouble creating a print template with it's associated legend, I decided to play around with creating my
own form that mimics how I want the template to look.  I have my main form which displays the map and let's the user pick which layers are visible.  They can then choose to print that map.  I then want to send them to my print form which will format the map/legend slightly differently that the display form.  I was wondering if it's possible to pass the map object between the two forms.
If this is not possible, then I'll get back to creating a print template.  btw, I was successful in creating a print service using the tutorial that RS sent me.
Drew
You will want to 'put' the map into storage. But I believe it has to be in JSON form.
storageProvider.put("myValue", myObject, function(status, keyName){
            alert("value put in "+keyName);
BrianFoley1
I tried the code from the first link to sent 'Export Map as JSON' :
   var printTask = new esri.tasks.PrintTask();
   var Web_Map_as_JSON = JSON.toJson(printTask._getPrintDefinition(map));
but get the following error:
JavaScript runtime error: Object doesn't support property or method 'toJson'
Drew
it looks like the function has changed a little.
Its more like
var webmap = printTask._getPrintDefinition(map, printparams)
Get the WebMap from Javascript API esri/map
