I want to open esri popup template from popup template on click of table data, Please find below image:
I want to show some charts related to feature layer, on click of table data as shown below:
Regards,
Shaikh Rizuan
Shaikh,
I do not have any code samples for your desired workflow but what is happening in your video you provided is that the feature has a click event that triggers a html element to be added to the app or an html element is set to visible. Not really anything to do with the maps popup.
Shaikh,
A popup is a singleton class for the map, meaning you can only have one popup visible.
Hi Robert,
Is there any other way around to get that kind of functionality, I want to implement in one of the widget of WAB (2.6). I have attached .gif file which i found in one of the ESRI link.
How can i achieve the above functionality?
Shaikh,
