I am pretty stuck and do not know what I am doing wrong. I am currently just trying to modify this library from Esri (https://github.com/Esri/esri-react-boot).
It uses OAuth, but you can view the map without having to sign in. However, if I want to modify the basemap config to show arcgis-topographic like the tutorial shows here (https://developers.arcgis.com/javascript/latest/display-a-map/), I do not get any render of the map.
The tutorial uses an API Key, but when using OAuth, you shouldn't need to do anything like that.
Below are the only 2 files I have modified, everything else is the same as in the repo.
config.json
"appVersion": "2.0.0",
"apiUrl": "api",
"loginUrl": "api/auth/arcgis",
"logoutUrl": "api/logout",
"jsapiUrl": "https://js.arcgis.com/4.17/",
"jsapiV4": true,
"clientId": "<hidden>",
"sessionId": "esri-react-boot_session",
"mapConfig": {
"basemap": "arcgis-topographic",
"center": [-118.805, 34.027],
"zoom": 13
package.json
"name": "react-jsapi-app",
"version": "0.1.0",
"private": true,
"homepage": "/",
"dependencies": {
"@esri/arcgis-rest-auth": "^3.0.0",
"@esri/arcgis-rest-portal": "^3.0.0",
"@esri/arcgis-rest-request": "^3.0.0",
"calcite-react": "^0.44.0",
"esri-loader": "^2.16.0",
"framer-motion": "^1.6.18",
"js-cookie": "^2.2.1",
"react": "^16.12.0",
"react-dom": "^16.12.0",
"react-redux": "^7.1.3",
"react-router-dom": "^5.1.2",
"react-transition-group": "^4.3.0",
"redux": "^4.0.4",
"redux-saga": "^1.1.3",
"styled-components": "^4.4.1"
"scripts": {
"start": "react-scripts start",
"build": "react-scripts build",
"test": "react-scripts test --env=jsdom",
"eject": "react-scripts eject"
"devDependencies": {
"react-scripts": "^3.3.0"
"browserslist": {
"development": [
"last 2 chrome versions",
"last 2 firefox versions",
"last 2 edge versions"
Thank you in advance.
