Robert,
Thanks so much for your prompt reply.
This is the code that I'm working with. I just use the startup method of the editor.
var layers = arrayUtils.map(evt.layers, function (result) {
return { featureLayer: result.layer };
var settings = {
map: map,
templatePicker: templatePicker,
layerInfos: layers,
toolbarVisible: true,
createOptions: {
polylineDrawTools: [Editor.CREATE_TOOL_FREEHAND_POLYLINE],
polygonDrawTools: [Editor.CREATE_TOOL_FREEHAND_POLYGON,
Editor.CREATE_TOOL_CIRCLE,
Editor.CREATE_TOOL_TRIANGLE,
Editor.CREATE_TOOL_RECTANGLE
toolbarOptions: {
reshapeVisible: true
var params = { settings: settings };
var myEditor = new Editor(params, 'editorDiv');
//define snapping options
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CROSS,
15,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0, 0.5]),
5
null
map.enableSnapping({
snapPointSymbol: symbol,
tolerance: 20,
snapKey: keys.ALT
myEditor.startup();
Mario E.
