I'm trying to adapt this example from Tamia Rudnicky and Christian Bischof where they create multiple layer lists with different layers.
I think the example above was adapted from this example by Robert Scheitlin, GISP. That example succesfully parses the layers into two lists.
arcgis-js-api-4.15
I'm hoping to get two of the layers to show up in the list on the bottom left and one layer to show up in the layer list on the bottom right. Right now, I can only control the layers in the list on the bottom left using:
view.when(function() {
watchUtils.when(lList, 'operationalItems.length', function() {
var elementsLeftList = document.getElementsByClassName('esri-layer-list__item esri-layer-list__item--has-children');
elementsLeftList[2].style.display = "none";
console.log(elementsLeftList);
Does anybody know how to control the layers that are visible in each list?
Mason
Here is the full code:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>Tahoe Imagery Swipe</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.16/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.16/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/TileLayer",
"esri/widgets/Fullscreen",
"esri/widgets/LayerList",
"esri/widgets/Swipe",
"esri/widgets/Expand",
"dojo/query",
"esri/core/watchUtils",
"dojo/dom-style"
], function(Map, MapView, TileLayer, Fullscreen, LayerList, Swipe, Expand,query, watchUtils, domStyle) {
const map = new Map({
basemap: "satellite"
const fifteenLayer = new TileLayer({
url: "https://maps.trpa.org/server/rest/services/2015_Imagery/MapServer",
maxScale: 3000
map.add(fifteenLayer);
const fortyLayer = new TileLayer({
url: "https://maps.trpa.org/server/rest/services/1940_Imagery/MapServer",
maxScale: 3000
map.add(fortyLayer);
const sixtynineLayer = new TileLayer({
url: "https://maps.trpa.org/server/rest/services/1969_Imagery/MapServer",
maxScale: 3000
map.add(sixtynineLayer);
const view = new MapView({
container: "viewDiv",
map: map,
center: [-120.01,38.93],
zoom: 15,
constraints: {
maxZoom: 17,
minZoom: 8
var lList = new LayerList({
view: view
var rList = new LayerList({
view: view
watchUtils.when(rList, 'operationalItems.length', function() {
var elementsRightList = document.getElementsByClassName('esri-layer-list__item esri-layer-list__item--has-children');
elementsRightList[2].style.display = "none";
console.log(elementsRightList);
view.ui.add(lList, "bottom-left");
view.ui.add(rList, "bottom-right");
var leftlayerListExpand = new Expand({
expandIconClass: "esri-icon-layer-list",
expandTooltip: "Expand LayerList",
view: view,
expanded: true,
content: lList.domNode
view.ui.add(leftlayerListExpand, "bottom-left")
var rightlayerListExpand = new Expand({
view: view,
expanded: true,
content: rList.domNode
view.ui.add(rightlayerListExpand, "bottom-right")
var fullscreen = new Fullscreen({
view: view
view.ui.add(fullscreen, "top-left");
const swipe = new Swipe({
leadingLayers: [fortyLayer, fifteenLayer],
trailingLayers: [sixtynineLayer],
position: 50,
view: view
view.ui.add(swipe);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
