Microsoft JScript runtime error: xhrFailed when switch V2.5 to V3.5
4001
01-28-2014 05:21 AM
ShaningYu
Honored Contributor
Got  Microsoft JScript runtime error: xhrFailed
and  Microsoft JScript runtime error: Object doesn't support this property or method
when switch V2.5 to V3.x (e.g. 3.5 or 3.8).
In V2.5 (or 2.7), I loaded the following 'requires'
      dojo.require("dijit.dijit"); // optimize: load dijit layer
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.form.Button");
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("esri.dijit.BasemapGallery");
      dojo.require("dijit.TitlePane");
      dojo.require("esri.tasks.query");
      dojo.require("dojo.data.ItemFileReadStore");
      dojo.require("dijit.layout.AccordionContainer");
      dojo.require("agsjs.dijit.TOC");
In V3.x, added the 2 below:
      dojo.require("dojo.dom");
      dojo.require("dojo.domReady!");
When I run the program, it breaks at init.js[dynamic] Line 265:
  require({cache:{"esri/layers/TimeReference":function(){ ... }  - as long as hundreds of lines.
Then I opened Fiddler2.  After the result of 302 on js.arcgis.com  /3.8/, I got some result of 502, e.g. the 1st one on  forums.arcgis.com//ajax.php?do=quickedit&p=361501
The 502 means  Bad Gateway.
Hopefully, you can share your experience to help me this issue.  Thanks in advance.
ShaningYu
Honored Contributor
Updated my script in API V3.8.  The prob. was identified to be
In V3.8, it needs defining the 'agsjs'
      var djConfig = {
          parseOnLoad: true,
          baseUrl: './',
          modulePaths: {
                            'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs'
              //'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/1.04/build/agsjs'  // in V2.x
ShaningYu
Honored Contributor
Refer to http://forums.arcgis.com/threads/101672-Error-502-Bad-Gateway-at-forums.arcgis.com-ajax.php-do-quick....  It is actually the conflict between JS API 3.x and jquery.  Using JS API 2.x should be fine.  However, some updated functions in 3.x can't be used.
ShaningYu
Honored Contributor
      var djConfig = {
          parseOnLoad: true,
          baseUrl: './',
          modulePaths: {
