We are in the process of re-writing a large internal web application that has 100's of users a day. I originally wrote this many years back using v3 (flex) and it is still functioning perfectly today. We are now in the process of a re-write using VueJS and so I am slowly getting intimate with the documentation for v4 but I am unfortunately not finding everything I need.
Onto my question:
We are loading in many MapImageLayers, some with 100's of layers/sublayers. Each of these MapServices have every single sublayer with a default visibility of false so that a user can fire up a LayerList/TOC component and switch them on or off.
The issue, which is probably due to my poor understanding, is that these sublayers do not exist in
mapImageLayer.subLayers.items unless I explicitly define them in the constructor with a visibility of false. I assume this is where findSubLayerById() looks?
Obviously I am unable to know these layer id's up-front so am I missing something obvious on how to add these sublayers correctly without having to specify them?
I can see all the sublayers in mapImageLayer.serviceSublayers but I have not been able to find this property documented so wonder if I should not be touching it?
Thanks for any help
Tony
